Why does White Smoke throw?
08.05.2020 17:45 # 1
baroff
Hello friends, the problems of this car are endless.
When I came on the road, I saw by chance when I pressed the gas visibly white smoke popped up occasionally, it throws smoke like this 2-3 times a day.
08.05.2020 17:45 # 2
hLL
White smoke appears in the following situations;
- Engine overheating.
- Missing burning (Usually due to late injection).
- Fuel spray hit on the cylinder walls smiliv cooling and accumulating.
- Low compression.
- Low volatile fuel.
- Low seton number (very delayed ignition).
08.05.2020 17:45 # 3
baroff
Vehicle diesel meanwhile 1.4 hdi
The engine overheated until about 100, then fell immediately.
It seems likely to be from the injectors, what do you think should be done for this?
08.05.2020 17:45 # 4
candanxyz
Change where you refuel, try it.
08.05.2020 17:45 # 5
baroff
Let me take VPower GTL from Shelld, I have Vpower here, but I don't write GTL in general.
The station I use now is Opet.
08.05.2020 17:45 # 6
koramiral
Neither motorcy nor smoke remains in the horse nor any other bisey :).
08.05.2020 17:45 # 7
Can Oksuz
See if there is any oil shortage. I know as fat burning.
