Why does the temperature of the car increase?
08.05.2020 18:46 # 1
acemi pecocu
The temperature indicator of my veteran 206 was 2 days ago, 90 is out right on my way, I said that I had the water in the gas station and the water was not working properly.
08.05.2020 18:46 # 2
ahmed206
At 206, the temperature rises up to 100 or even 110, but of course it shouldn't be too tight. Don't stop when he stops, let him work at idle and rest.
08.05.2020 18:46 # 3
acemi pecocu
so this is a normal event then the ones on the oil are exaggerated Confused they said you burn the gasket I was scared too
08.05.2020 18:46 # 4
ahmed206
When I first bought the car, I looked at the temperature from 80 to 100, I was afraid in congested traffic, burned the four signals and waited somewhere on the right. In other words, the afraid petrol stations who do not know the pejo car are afraid, so they warned you. If you still have a question mark in mind, ask someone who drives from the same vehicle, even take a look at his car, whether the temperature is in the same place.
08.05.2020 18:46 # 5
TaZ
I have just traveled 5 thousand km, including 4 thousand long roads, 1 city. There was no problem until I went to Malatya. It was great. It was great. I stopped in traffic in the heat of malatya. I wrote a stop letter or something. I had to unplug it, I used to pull out the plug, I was in Malatya for 15 days, every contact was opened, I started to work directly in the fan until I stopped, I stopped without any trouble until I stopped, I came back to Istanbul, I took it to the master, the fan role of the fan role was burned, the other was the first step, the fan was closed, the first step was not enough, the first stage fan was hungry, the first step was not enough, the first stage fan was closed. based on the I do not trust the masters in gasoline, I do not trust the men in gasoline :) I do not trust the masters. you can go safely.
08.05.2020 18:46 # 6
acemi pecocu
I'm glad I joined this site ALLAHUTEALA brothers and sisters lonely, whatever you take a picture
08.05.2020 18:46 # 7
acemi pecocu
Let's look at it tomorrow. After that, there is a way to industry. 8 to 10 TL.
08.05.2020 18:46 # 8
outlaw
I have 2 fans, one of them made a button from the inside ...
As soon as the weather is very hot, I open that fan as soon as I start the car.
08.05.2020 18:46 # 9
muhammed.ceyhan
I have 2000 models 206 too. the temperature is continuous in the city 90. I went on a holiday in Bursa. 90-100 temperature is quite normal in peugeot. These are the hot runs. LOL
08.05.2020 18:46 # 10
cavit cevo
When the air conditioner is turned on, the fan is also activated, if the air conditioner gas is full, the fan runs continuously.
08.05.2020 18:46 # 11
yillmaz
I do not know about your vehicle, but generally the working system is the same.
Avoid running over 95 degrees continuously, it decreases vehicle performance.
  1. If the temperature is rising and falling, the fan may not be running.
  2. It may be clogged in the radiator.
  3. Since the water circulation system makes air, it does not cool. If this was a problem, you would have already burned the seal
  4. the thermostat in the radiator may be faulty.
  5. the sensor on the engine is faulty, it may display incorrect information on the screen.
  6. fan, thermostat cables may be contactless, connection to the connection may be broken.
08.05.2020 18:46 # 12
acemi pecocu
I could not bring the veteran because the work was intense, I showed him in the service of reno today, I showed him that the service master friend said the fan is not working.
08.05.2020 18:46 # 13
madblueblacksea
It plays around 90 in its normal course and turns on 96 fans. Why are you seeing 90 as a problem?
08.05.2020 18:46 # 14
acemi pecocu
No problem, not 90, but 100 passes today, the master said the fan is not working, approaching the limit, I'm 200 km, I was going to learn to those who responded.
08.05.2020 18:46 # 15
yalcinoto123
http://www.peugeototocikma.com/peugeot vehicles have 90 overheating is normal, if over 90 there may be air in the water system
08.05.2020 18:46 # 16
madblueblacksea
[QUOTE = yalcinoto123] http://www.peugeototocikma.com/peugeot 90 temperature is normal and above 90, there may be air in the water system [/ QUOTE]
Up to 100 can be compressed. In a motor that already turns on a fan in 96, it turns up a little more until the fan turns on and the water in the engine winds up from the radiator and reaches cold air.
08.05.2020 18:46 # 17
acemi pecocu
I came from the industry an hour ago, showed it to the electrician, veteran maşALLAH had nothing, my red lightning can go over 100 as the friends say, so it was normal, but I was relieved, and in this incident, I wrote to the information that we learned the heat in the event.
08.05.2020 18:46 # 18
Don't be afraid 90 degrees is normal, don't be afraid going on in my 307.
08.05.2020 18:46 # 19
emreeee
While I am on the normal road in 307, I am between 70 and 80, but I can see the light ramp, or I will stop and let it go 90 minutes in a minute. Cry
08.05.2020 18:46 # 20
Amon
The temperature of my 206 vehicle was based on the red zone. The service industry was turning on a solid fan, saying that it made air, and taking the air, saying it was moving. When I went again, the peugeot was not afraid if it turned on the fan. While I was on the long road, I thought that the engine would be burned. But the red zone came to the last stop and stood there. Even when the indicator was defective, something came to my mind when I was thinking that this was what happened someday. I knocked from the ground, so let me go from the front, I rubbed the bumper when I said to the sidewalk, then came back a little bit and parked like that. raç opens the first stage fan, the 2nd stage fan is canceled.It is insufficient.If the master told the situation, he looked down and made the diagnosis.35 TL to save the engine from burning in 9 months, I did not go to the master. I finally found myself stopped. It is a very sensitive piece, but no one will think of it. Because when the first stage fan turns on, the masters immediately turn on the fan and they say no problem.
