Why does the steering wheel vibrate on straight road?
08.05.2020 18:31 # 1
kuantum
Why can the steering wheel vibrate when traveling in TEM?
08.05.2020 18:31 # 2
outlaw
BALANCE ADJUSTMENT
08.05.2020 18:31 # 3
there is no balance,
Brake discs are problematic,
The rim is trapezoid,
In-rim bracelet not installed
dogan106 2014-05-07 17:44:39
08.05.2020 18:31 # 4
Burak
[QUOTE = dogan106] there is no balance,
additionally may be caused by tires
08.05.2020 18:31 # 5
DeRyCK
If the brake vibrates to pressure, the discs are distorted. vibrates without pressing, but it may be due to wheel, tire and balance.
08.05.2020 18:31 # 6
samet206
* The rim is crooked.
* Wreck old is damaged, wires are damaged.
((The most obvious possibility is that the balance setting is off.))
* Skew can occur in the disks.
* A possibility may be a problem in the axle. On this vehicle, vibrations in the transmission and steering can create jolts.
My suggestion is that the first thing you need to look at is the balance adjustment of the wheels.
