Why does the gasoline needle drop when traveling on LPG?
08.05.2020 16:41 # 1
Gokcesel
Hello friends, last month, I got an OMVL brand LPG system on my 206 model car last week, I bought 50 pounds of gasoline on Tuesday, I went up from the quarter tank, I did not use the car in gasoline, I also used the LPG at the bottom of the quarter tank, but I did not understand why the gas needle is right in the middle with the red line. he does like this. Does this car consume both gasoline and gas? Can you help me why? what should I do
08.05.2020 16:41 # 2
There is a great deal of information on this topic in the forum. One of them:
http://forum.peugeotturkey.com/forum_posts.asp?TID=13780&title=lpg-de-benzin-ibresi-dmesi-sunu-ucuz-zm
08.05.2020 16:41 # 3
hakan38
My teacher is just working when you buy gasoline. Then the wheel starts to die. I always know.
08.05.2020 16:41 # 4
Emre GOK
Friends, I have the same problem with me, while the gasoline needle is constantly falling, I put 20 30 gasoline every week, even though I use LPG on my vehicle, I stay on the road, I don't understand how the gas runs out so quickly.
08.05.2020 16:41 # 5
mhtm05
[QUOTE = Emre GÖK] Friends, I have the same problem with me, the gasoline needle is constantly falling, I also add 20 30 gasoline each week, I stay on the road even though I use lpgli how I run out of gas. [/ QUOTE ]
How do you get on track? Does the engine stop when the petrol needle hits the bottom in the 307s ??? I would appreciate if you answer ... mhtm05 2012-10-10 14:31:25
08.05.2020 16:41 # 6
maestro
[QUOTE = mhtm05] [QUOTE = Emre GÖK] Friends have the same problem with me, while the gas needle is constantly falling, I put 20 30 gasoline every week, even though I use lpgli every week, I stay on the road, I do not understand how the gas runs out so quickly. [/ QUOTE]
How do you get on track? Does the engine stop when the petrol needle hits the bottom in the 307s ??? I would be glad if you answer ... [/ QUOTE]
I have been walking at the bottom for almost 1 month. There is no such thing as quitting. > 2012-10-10 21:08:02
08.05.2020 16:41 # 7
berk2309
My maestro teacher, you have gas, but the iron-on-brew & nbsp; after burning the gasoline to pop up:) & nbsp;
08.05.2020 16:41 # 8
msertkol
I also had the problem of needle drop. I was never interested. He crowded and then came on his own. I already knew that there was half a tank of gasoline. I trust my vehicle. I like that sound very much, it starts when the Fuel Level Low article appears. It feels like I'm riding in a spacecraft, then it is silent :)
08.05.2020 16:41 # 9
gngburak
I complained about the same problem, but don't be afraid, the gasoline is standing in the warehouse
I did research on the site. DIV> The engineer who made the car should not have thought that we would install lpg .....
08.05.2020 16:41 # 10
elsoberano
& nbsp; when the tank is above the half tank Even if the needle falls, it stops and starts again. "0" alt = "Smile" title = "Smile" /> we currently manage
08.05.2020 16:41 # 11
sezar206
I have been using the vehicle for two years, unless you use gasoline, you have no question. Have a control burn the LPG and petrol at the same time? Do not drop the gasoline in the tank below the last white line, I think you can spoil the pump. It's too expensive. I looked at the float of the warehouse and it was like the last 250 TL.
08.05.2020 16:41 # 12
pierson
[QUOTE = gngburak] I complained about the same problem, but do not be afraid, gasoline is standing in the warehouse.
The engineer who built the car shouldn't have thought we'd get the lpg .....
now my petrol needle is normally in the quarter tank ... ..If I buy 10 TL of alcohol, this needle will increase 10 TL or more ... ???
08.05.2020 16:41 # 13
impact
It does not increase at all, it does not affect the gas consumption of certain lt. Do not put it below 30-35 ..
08.05.2020 16:41 # 14
pierson
If you always put 30-35 TL gasoline in the end, the tank will be overflowing.
08.05.2020 16:41 # 15
palet
If the gasoline level in the tank is literally 4/3, the gasoline needle will drop for a while, even though the vehicle is used in LPG. When the gasoline level drops below the quarter tank, if you close the ignition for any reason and start the car again, this time the pointer resets itself and returns to the 4/3 position. and the gas pump can be cooled by the gas passing through it. Since the pump will run dry in case of a decrease in gas in the tank, the probability of burning the pump will increase considerably. It is necessary to nominate friends who can achieve this to the Nobel Prize in Physics.
palet 2015-02-28 16:29:57
08.05.2020 16:41 # 16
talip206
This is Peugeot's chronic problem. it does not waste gasoline but the needle drops. Either the tank will have gasoline or it will recover when parking on the slope
08.05.2020 16:41 # 17
206cc_yasin
CAN GET INTEGRATED TO LPG
08.05.2020 16:41 # 18
gogly35
same problem with me unfortunately i am tired of touring the petrol light burned, i am getting 25-30 TL in the meantime playing the pointer then the light is on again .. well do we have the opportunity to see the gas level in the tank ??
08.05.2020 16:41 # 19
palet
[QUOTE = gogly35] same problem, unfortunately, I am tired of having a petrol light on my head, I am getting 25-30 TL in the meantime, the hoop is playing again, the light is on again .. well, do we have the opportunity to see the gas level in the tank ?? [/ QUOTE]
< / div>
& nbsp; & Nbsp; If you keep the amount of gasoline in the tank at least 3/4, if the light turns on, if you turn the ignition off and on, or if the tank is shaken, the light will go out and the pointer will come to its real position. You will need to purchase 20-25 TL gasoline only so that the gasoline level does not drop below 3/4. You must buy gasoline to see the real level. Gasoline passing through the tank filling neck during filling resets the needle. either you will have some gas at hand and when you wonder the level, you will add to the tank from the filling mouth or you will keep the real gasoline at 3/4 as I said. & nbsp;
palette 2015 -03-01 16:14:06
08.05.2020 16:41 # 20
lamazibici06
I had the same problem with me, the buoy was broken
