Why does the balanced car vibrate?
08.05.2020 18:26 # 1
muku
mrb friends, yesterday, I installed zero tires on my 17 rims, but the wheels were crooked, straightened, he made the leveling balance, the machine showed zero in front of my eyes but when I got home there was a tremor when I passed 90. My question is why does the tire vibrate if the balance has been reset? Is there anything the mechanic can do in this?
08.05.2020 18:26 # 2
Alicilik
It may be from the axle ball if it is doing at a certain speed range. There was a serious tremor in my vehicle between 90 and 120, after 130 it was interrupted. The axle ball has improved as it changes.
08.05.2020 18:26 # 3
C@GL@R
If you have the rod settings done, it will not be just by balancing. Check the rot settings too. If there is no problem, the man will not receive money.
08.05.2020 18:26 # 4
muku
There was not much tremor when there was winter tire, it came out when the wheels were buried, wouldn't it tremble when it was winter
08.05.2020 18:26 # 5
I think there is no bracelet
08.05.2020 18:26 # 6
muku
[QUOTE = dogan106] I think there is no bracelet [/ QUOTE] Bracelet?
08.05.2020 18:26 # 7
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-aksesuar-ekipman-celik-jant-icin-bilezik-146797482/detay
You can examine what happened here / what it works for, the details are written below, but the price is normally not more than 5 TL at any tire / balancer.
08.05.2020 18:26 # 8
muku
[QUOTE = dogan106] http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-aksesuar-ekipman-celik-jant-icin-bilezik-146797482/detay
[/ QUOTE] I understood that they did not fit mine, but my rim is different from the factory rim, 206 and c4 hubs used in some models of citroen c4.
08.05.2020 18:26 # 9
BG307
Replica wheels may not adjust, the rear tires are front, probably the problem.
08.05.2020 18:26 # 10
mistercasper
my teacher also have a balance on the car, the old style is much better than the computer
08.05.2020 18:26 # 11
[QUOTE = muku] [QUOTE = dogan106] http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-aksesuar-ekipman-celik-jant-icin-bilezik-146797482/ detail
[/ QUOTE] I understood that they did not fit mine, but my rim is different from the factory rim, 206 and c4 hubs used in some models of citroen c4 [/ QUOTE]
I'm not sure, is there any gap?
08.05.2020 18:26 # 12
ahmed206
[QUOTE = mistercasper] My teacher also have a balance on the car, the old style is much better than the computer [/ QUOTE] How do they do it ...
08.05.2020 18:26 # 13
[QUOTE = ahmed206] [QUOTE = mistercasper] get a balance on the car, old method, it is much better than a computer [/ QUOTE] How do they do it ... [/ QUOTE]
must have a donkey balance Big smile
08.05.2020 18:26 # 14
Bugra
He started trembling after removing the wintry in me. But according to his head, sometimes titry, sometimes not trembling. recently started shaking after 90. I showed it to the master, the right upper engine wedge is from this pear wedge called. I changed it now, I tried, no shaking. but as I said it is irregular. sometimes it does, sometimes it doesn't. sometimes it vibrates when going 40 in 2nd gear. Now it seems like no problem.
when he wasted off the axle, he stopped shaking. When I was idle, my titry was sometimes.
I said something like that sometimes there is sometimes not. If you want, look at a wedge.
08.05.2020 18:26 # 15
muku
Now I will go back to the man, we will reset the balance, you will see it, I will go to the man, I will ask you what we will say in the evening
08.05.2020 18:26 # 16
ahmet_bjk
my car was starting to vibrate after 120, but sometimes it was shaking, sometimes it was not. I checked the settings so that it could be from the rot setting, but there was no problem. Sometimes it flickers at 130, sometimes it doesn't flicker at 160-170.
I think it is either from the axle ball that Ali said or it is caused by the road.
Was Ali constantly trembling in your vehicle?
08.05.2020 18:26 # 17
samet206
I could have been doing it at the axle, I had a problem at the axle, but recently started again, the gear knob is shaking in the 2nd gear. The vehicle, which may be caused by a situation related to traction with a possible axle traction, is so sensed that it does not make a vibration, pulls it left and right.
08.05.2020 18:26 # 18
muku
ANCHORFREE_VERSION = "623161526" var _AF2 $ = (`` SN`: `HSSHIELD00TR`,` IP`: `54.81.114.111`,` CH`: `HSSCNL000561`,` CT`: `oxm, z309`,` HST`: `& sessstartti to = 1397150981 & accesslp = 1 & BCHROME = 33 & pv = 2 & NUM_VID = 0 & NUM_VID_TS = 1397150996 & in = 1397152200_19179883 | d, 53451750 | w 1337957320 | m, 2610902771 | t & out = 1397152200_4508860 | d, 13264351 | w 96472630 | m, 164834126 | t & SFLAG = 1 & av = 3 & fvidat 7 & clsbtncnt = 1`, `AFH`: hss208`` `RN`: Math.floor is (Math.random () * 999), 'TOP` (parent.locatio the! = top.locatio the document.location ||! = document.location)? 0: 1, AFVER` `` 3.32` `fbw`: false, FBWCNT`` 0, `FBWCNTNAME`: FBWCNT_CHROME`` `NOFBWNAME`: NO_FBW_CHROME`` `B`: `c`,` VER`: `nonus`}; if (_AF2 $ .TOP == 1) {document.write (" ");} friends, as you said, I got the balance on the vehicle, the front is straightened, there is no tremor in the steering wheel, but the rear is still stern, thanks for your help in the future. Thanks for your help, I put it in the pictures on the weekend.
08.05.2020 18:26 # 19
Bugra
Shouldn't it stop trembling when you throw it away from the axle?
