WHY DOES PUG 106 MAKE SOUND IN BACK GEAR?
08.05.2020 17:43 # 1
superyusuf
Mrb friends. Today it happened to me. I put it back in gear. The car is knocked.
08.05.2020 17:43 # 2
konyali42
Yes, I have the same in me. Sometimes it is not a matter to throw the gear, we should not get up without throwing it.
08.05.2020 17:43 # 3
superyusuf
Hopefully as you said. If the sound doesn't go away, where is the problem?
08.05.2020 17:43 # 4
konyali42
I tried a lot, there is no nice tactical sound in my vehicle about shifting gears, but it sounds like it is a little bit of a boat, it is due to the fact that the gear gears do not fully grasp each other.
08.05.2020 17:43 # 5
superyusuf
God willing
08.05.2020 17:43 # 6
superyusuf
[QUOTE = Honor] Your sister gear is half past yes it goes back but it can break the tooth. you get that gearbox, you hold it in the hands of the mechanic ... Since the reverse gear is positioned in a very different position of the gearbox (at the pejo), you need to shift the gear to the bottom of the clutch without pressing , the handbrake when engaging the gear should be not , also the vehicle forward If you are driving, you should not reverse the gear in these cases. most of the time it makes half passes.
08.05.2020 17:43 # 7
superyusuf
thanks
