Why does not he eat gas in gas?
08.05.2020 18:46 # 1
korombo
Hello friends.
My car is Peugeot 206 Sedan 2007 model Lpg.
The problem I can't solve in the car is that I run it when it is cold in the morning, it stops. I turn the contact 2 -3 times, then the vehicle throws itself into the LPG and continues its normal operation. If I immediately throw gasoline at that moment, it does not eat gas when I touch the gas. When the vehicle warms up, it does not eat gas at low speeds, it recovers as the speed increases.
We replaced the spark plugs, cleaned the throttle, replaced the gas pump. I'm going crazy. I couldn't sort it out. It works normally in LPG. When I take the gas, it seems like the car will drown when I touch the gas ...
I hope there are those who know the solution, thanks.
08.05.2020 18:46 # 2
Foxfire
lpg atiker
08.05.2020 18:46 # 3
Efe-Pojo
I have not been asked, but let me give the answer 90 percent of it because I have exactly the same problem with my friend. I have an attacher attached. However, when you use it only for a certain period of time, the vehicle becomes itself day by day.
08.05.2020 18:46 # 4
_ali_
http://forum.peugeotturkey.com/forum_posts.asp?tıd=30861&pn=2&title=motor-sogukken-benzinde-teklemeyigilmaguncel
08.05.2020 18:46 # 5
korombo
Eureka4 lpg
08.05.2020 18:46 # 6
korombo
Thanks for the link, but solutions for that matter are not working either. I guess the same thing. Why it is so interesting in a gas-powered car
