Why do you think my 307 Triptronic does not pass?
08.05.2020 17:22 # 1
EnSoNiQ
Hello, I wanted to overtake a vehicle today, I bought triptronics directly, but I stayed on the screen and it did not go to triptronics, it continued as if the engine temperature was around 80 degrees. I am waiting for your help.
08.05.2020 17:22 # 2
ondercan
hello & nbsp;
actually, it is necessary to connect to the computer. But when the gear is shifted on the gearbox, there is a big contactor that informs the brain about which gears it shifted. div>
make it easy
08.05.2020 17:22 # 3
EnSoNiQ
Let's see if I will take a weekend to connect to the computer, but I wanted to get your opinion, it says d on the screen, it stays and goes as if it was automatic.
08.05.2020 17:22 # 4
ondercan
There may be a problem with your reader. It is under the gear lever. It may not detect that you are taking tripton.
it looks like an electronic card.
08.05.2020 17:22 # 5
katipahmet
I had a similar problem. they replaced a part that they called a position conditioner or a position sensor. A process that takes about 45 minutes or so on the transmission's upper daughter. I gave 150 TL for parts and labor. I had it done in a private service outside. The problem has also improved. Strongly likely yours is something like that. Of course, first of all, you need to connect it to the computer and have it checked.
