Why Can My Vehicle Burn So Much?
08.05.2020 17:21 # 1
AzoReSx
& nbsp; Have a Good Day & nbsp;
My car 2006 model 307 1.6 comfort triptonic vehicle has BRC brand tube attached & nbsp; while the car is hot, my car is burning between 50 55 cents with a gas of 35 TL. I can go exactly 20 km. Since the hawah cools down, there is no such increase. & Nbsp; What could be the problem? and how much it costs me to solve this situation. & Nbsp; & nbsp;
& nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp;
08.05.2020 17:21 # 2
Bugra
It is normal for gas vehicles to burn more in winter, but I did not know if the difference in your vehicle is normal.
08.05.2020 17:21 # 3
xdesign_206
I think it is very close because the gas setting is broken, I think you should do the gas setting.
08.05.2020 17:21 # 4
istanbullu_3886
First of all, the fuel will increase in the winter and if the air filter is dirty, the vehicle will burn more.
08.05.2020 17:21 # 5
zgr
It is true that fuel increases in winter, but it is abnormal to increase this much. Have lpg maintenance. For my lpg kit, it is said that every 10,000 lpg filter should change. After this change, they also adjust the gas. mine was starting to burn too. I inserted it last week for maintenance, 30tl. I bought gas 102 km. gas is not finished yet. (liter of gas makes 2.35 tl & nbsp; 30 tlgaz = 12.76 & nbsp; lt.). (by the way & nbsp; I did not go any way with gasoline during the measurement. I waited for it to switch to LPG in place after running.) My advice is to book your lpg maintenance and compare again.
08.05.2020 17:21 # 6
AzoReSx
[QUOTE = zgr] It is true that fuel increases in winter, but this increase is abnormal. Have lpg maintenance. For my lpg kit, it is said that every 10,000 lpg filter should change. After this change, they also adjust the gas. mine was starting to burn too. I inserted it last week for maintenance, 30tl. I bought gas 102 km. gas is not finished yet. (liter of gas makes 2.35 tl & nbsp; 30 tlgaz = 12.76 & nbsp; lt.). (by the way & nbsp; I did not go any way with gasoline during the measurement. I waited for it to switch to LPG in place after running it.) My advice is to book your lpg maintenance and compare again. [/ QUOTE]
average maintenance cost how much ? Thank you for your interest.
08.05.2020 17:21 # 7
rhcpeppers
I stung too, took 60 lira
08.05.2020 17:21 # 8
hema123
Sequential system Factors affecting fuel in LPG vehicles:
1- The decrease in ignition quality reduces combustion efficiency and makes it very burning. & nbsp; the most important symptom is the vehicle's traction is reduced and the unburned lpg smell is heard from the exhaust. The remedy is to renew the ignition coil, spark plug cables and spark plugs. Again, the contacts in the ignition system must be clean. Under tr conditions, an air filter replacement is required every two months or every 5 thousand km. It pays for the spent money in one or two tanks of gas.
3- When calculating the lpg consumption, the empty tank should be calculated from the empty tank. The pump filling the tank does not provide the same pressure every time. Also, the pressure of the different pumps will be different. For example, one pump can press 30 liters into the gas tank, another pump or at the different time of the day, the same pump can load 50 liters of lpg into the same tank. The healthiest consumable account in LPG should be to take a certain amount of LPG into the completely empty tank and use it until it finishes. 5- Exhaust end muffler obstruction-disorder is one of the most important fuel-boosting factors in LPG vehicles. What I did in my 1998 bmw car in 2009, I couldn't bring the fuel back to normal. When I was about to give up, I changed the muffler with the guidance of a skilled craftsman and became full of fuel.
6- lpg kit assembly errors increase the fuel. If the hose between the connection in the manifold and the LPG injectors is longer than 10 cm, it is not possible to fix the adjustment. Weather conditions are beginning to affect the LPG consumption at an advanced level. & nbsp;
7- The effect of routine maintenance of the LPG kit on fuel is a known fact.
it can be quickly affected by fluctuations in the vehicle's electrical-electronic system and its adjustment may escape. It may be necessary to make adjustments from time to time.
9- If the clutch lining is well reduced, the fuel will increase. Significant reductions in automatic transmission hydraulics also give the same result.
10- If the brake fluid is very old and / or blockages preventing return, the brakes remain tight and increase fuel. / div>
I have listed the most important reasons that I can think of for now. then, if I think of new things, I will continue.
with best regards.
