Why Boschmann Amphitheater Extinguished?
08.05.2020 19:23 # 1
weezyy35
Hello friends, I have a boschmann amp and I have been using it for a long time, yesterday the sound was very quiet around 5 pm I turned off the tape later. When I turned it on to listen again, I saw that the sound came from the front 2 twitter. I looked at the amplifier, his light was not on. I looked at the fuses on the amphitheater, it looked normal, the explosion did not crack. I checked in the fuse in the battery, the room looks just as solid. What else should I check in you? Cry
08.05.2020 19:23 # 2
I have to take it to the auto electrician, and my teacher's amp may have been broken. looking at the electrical inputs and outputs can be a voltage related situation.
08.05.2020 19:23 # 3
emre41
You have to look at the trigger (rem) cable. It is a thin cable that may be broken.
08.05.2020 19:23 # 4
weezyy35
I wonder where the cable was, I cleaned the day, I deleted the bottom of the confirmation, could it have been from the inside, but then I got into the car, this problem happened during the day, did it come loose.
08.05.2020 19:23 # 5
you may have a check that the inputs are loosened by your hand
08.05.2020 19:23 # 6
weezyy35
I will try it in the evening, I will share the result with you guys.
Thanks
08.05.2020 19:23 # 7
serdaralisan
If you couldn't, my friend, the blue antenna cable that provides an amphitheater switch off the power from the back of the tape, cut the power from the battery to the other opening on the amplifier. I switched to the brand of the alpine, it is not an amp that makes a lot of malfunction. I have a pioner with a 25 cm cabin woofer I have a jaguar brand monoblock 400 asset amphitheater one bossman 30 cm woofer attached to my vehicle 106 of them are playing in this vehicle.
08.05.2020 19:23 # 8
weezyy35
I got a little bit stuck, but I did not get any results, thank you for the information you provided, I would like to show it to a master, maybe it has a simple job.
08.05.2020 19:23 # 9
madblueblacksea
To find out if the problem is with the trigger cable from the tape, short-circuit the + connector and the rem connector with a thin cable to check the condition of the amplifier. If it works, check the cable from the tape that is triggering the problem.
08.05.2020 19:23 # 10
weezyy35
Yes, my friends were in the rem cable. We pulled the cable again and the problem was fixed. Thanks for your help. LOL
