who knows what torsion means?
08.05.2020 17:49 # 1
206FR
I do not know what torsion means, everyone says that I will drop torsion while cutting or changing auger?
08.05.2020 17:49 # 2
murateest
[QUOTE = 206FR] I don't know what torsion means, everybody says I will drop torsion while cutting or changing the screw? [/ QUOTE]
I recently changed the torsion bushes of the flash.
< / div>
Something like this.
08.05.2020 17:49 # 3
KenBlockJR
the http://lmgtfy.com/?q=206+torsiyo
08.05.2020 17:49 # 4
206FR
[QUOTE = murateest] [QUOTE = 206FR] What does torsion mean? I don't know what everyone says I will drop torsion while cutting or changing the screw? [/ QUOTE]
< div> so how to download the teeth in this and what is doing this friend doing what I will cut the helix by myself so I research it here, there is no master event, so it is :)
08.05.2020 17:49 # 5
murateest
There are two shafts in the pipe, you take them out and lower the teeth.
But it's a pretty hard job.
08.05.2020 17:49 # 6
murateest
In the meantime, if you do not lower the teeth at the same rate, one side of the rear of the vehicle may remain above and one side below, it is stable with experience :)
08.05.2020 17:49 # 7
Mustafa-almanya
[QUOTE = 206FR] [QUOTE = murateest] [QUOTE = 206FR] I don't know what torsion says, everybody says I will drop torsion while cutting or changing the screw? [/ QUOTE]
I changed the horoscopes.
so how is it downloaded and what does this friend do? div>
Brother, you will cut the springs, get the eibaches that fit the tool from ebay. If you have problems in the examination, you can run the new springs to the vehicle & nbsp ;, drive without a question. & Nbsp;
08.05.2020 17:49 # 8
206FR
thank you very much I was just looking at the french sites about the vehicle part I never thought of e-bay: D
