Who Complain Of Engine Sound In 307? |
| 08.05.2020 18:51 | # 1 |
I bought a new 307 1.4 HDI XR. I have a question for you. I changed all the filters and oil as I bought the car. I put 5W-40 Castrol Edge oil. But the sound of the engine sounds too loud to me. I was using Clio 1.5 DCI before. Even more than that, the engine sounds into the vehicle. What is the situation in your vehicle?
| 08.05.2020 18:51 | # 2 |
Diesel 307s sounds a little too many models by the way? tar-tar-tar-tar sometimes I can say that it is 307 coming from the street without seeing the car. |
| 08.05.2020 18:51 | # 3 |
First of all, thanks for the answer. My car 2005 model is at 135,000 km. Until this time, their maintenance has been done regularly in the service. |
| 08.05.2020 18:51 | # 4 |
I do not hear the sound of the 307 1.4 hdi engine in my car. I think it has a very quiet engine. There is a problem in your car.
| 08.05.2020 18:51 | # 5 |
[QUOTE = istanbulsporlu] First of all thank you for the answer. My car 2005 model is at 135,000 km. Until this time, their maintenance has been done regularly in the service. [/ QUOTE] As I said, good luck, as I said, I see the sound problem, I find it normal for a 10-year-old vehicle, I think there is no problem, yet 307 owner can help more experienced friends. |
| 08.05.2020 18:51 | # 6 |
I know that the mileage of the vehicle is original. The oil has also just changed. Any blowing in the engine, etc. there is no. Why would he be so loud?
| 08.05.2020 18:51 | # 7 |
[QUOTE = istanbulsporlu] I know that the mileage of the vehicle is original. The oil has also just changed. Any blowing in the engine, etc. there is no. Why would he be so loud? [/ QUOTE] then the sound is not good sound insulation of the vehicle. There are isolation felts on the back of the engine and on the hood that prevent the sound from entering. Check them out.
| 08.05.2020 18:51 | # 8 |
As the km of the vehicle increases, the sound changes. The higher the km, the higher the sound increases. The diesel engine is able to set up. Over time, the solution is turbocharged or changed. |
| 08.05.2020 18:51 | # 9 |
Thanks both to samet206 and dehsetilyo. I will have what you say when I go to the master. |
| 08.05.2020 18:51 | # 10 |
If I have the felts I said, make your car get a carbon clean and the sound will decrease at least 10 percent
| 08.05.2020 18:51 | # 11 |
I will look at the felts first thing in the morning. I heard about Carbon Clean, but I'll investigate the details.
| 08.05.2020 18:51 | # 12 |
tongucuk |
my car is now at 152000 km, 1.6 hdi engine sound is zero or even I do not exaggerate, I know that after starting the car, I forgot and started again, I witnessed a couple of friends in the forum, probably there is a problem in your car, I think |
| 08.05.2020 18:51 | # 13 |
Yes, the front hood felt has been removed. They want 250 TL for the original. I will ask the publishers. Do you think the sound will be cut off largely when you wear it?
| 08.05.2020 18:51 | # 14 |
[QUOTE = istanbulsporlu] Yes, the front hood felt has been removed. They want 250 TL for the original. I will ask the publishers. Do you think the sound will be cut off largely when you wear it? noticeably cut
| 08.05.2020 18:51 | # 15 |
In my 307 2005 model 1.4 hdi diesel sometimes I go down from the car and look at it, sometimes I start cranking while the car is so quiet.
| 08.05.2020 18:51 | # 16 |
endorphine |
No need to get off the vehicle. Just take a look at the tachometer. :)
