white smoke from exhaust |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 15:16 | # 1 |
| 08.05.2020 15:16 | # 2 |
If the car is near blue and white but blue smoke is burning, it is burning oil man Is there smoke when looking at the vehicle a little compress exhaust while stopping
| 08.05.2020 15:16 | # 3 |
I looked at it carefully. The smoke is not black. It is certain. But I examined it carefully. .
| 08.05.2020 15:16 | # 4 |
Let the car squeeze a little while it stops, it throws smoke yeah ..
| 08.05.2020 15:16 | # 5 |
My friend burns big oil, open the door when you add oil and look there, smoke will come from there. You will do it while you work. There will be a sudden change in the operation of the car in the first opening of the oil cover.
| 08.05.2020 15:16 | # 6 |
metin |
I know if it is dangerous to open the oil cap or remove the dipstick while the vehicle is running.
| 08.05.2020 15:17 | # 7 |
I will start the car..when I open the oil cover, I will check if there is smoke ... I will take the oil sprinkler while the car is running.
| 08.05.2020 15:17 | # 8 |
Segment roads seem to me ..
| 08.05.2020 15:17 | # 9 |
If the moment you stop is gasping and the bluish smoke comes out until the upper ages, then the machine says there is sullenness.
| 08.05.2020 15:17 | # 10 |
if white smoke comes out?
| 08.05.2020 15:17 | # 11 |
Brother, check if you have a fat tear on your vehicle, if you couldn't understand something
| 08.05.2020 15:17 | # 12 |
Thanks to the application, whatever you say .. If the smoke comes out, nobody calls it bluish smoke, I get stuck on it .. How many kinds of smoke can come out of this exhaust? I am asking because I do not know .. the sharing area is here .. nothing wrong ..
| 08.05.2020 15:17 | # 13 |
Be careful when opening the oil cap. because some of the engines can leap out of oil ... let me know the same things in my friend already :) If there is a blow, there will be an indicator of wearing ...
| 08.05.2020 15:17 | # 14 |
ok thanks thank you ..
| 08.05.2020 15:17 | # 15 |
I opened the oil cap 5 minutes after the car started .. there was no smoke or steam ... I looked at the oil stick too there was no smoke in it .. when the car started, it was blowing a very light smoke (I think white) .. I am traveling for 5-10 minutes more snra. There is a smell coming from the exhaust.
| 08.05.2020 15:17 | # 16 |
Do you have silencers in the vehicle? catalyst middle silencer original of the last silencer_? There is no more smoke after the first run.
| 08.05.2020 15:17 | # 17 |
Well, there is abart exhaust in the car ... there is smoke in my first start ... not in an excessive smoke, but there is ... no smoke after that ... so let me tell you ... I get out of the house and start the car ... it burns smoke when it is loaded where I am. Then I go to the workplace, which is about 5 km away. I check there is no smoke ..
| 08.05.2020 15:17 | # 18 |
Serhun |
In addition to other articles, it does, even if your oil is old, as it is generally done when it is cold. |
| 08.05.2020 15:17 | # 19 |
I had a problem. Thank you all for your help ..
