WHITE SMOKE ATM
08.05.2020 17:56 # 1
sametbeder
Hello friends ...
First of all, make it easy for everyone. There is a subject I would like to consult with you ... My vehicle 2004 model 1.4 HDI 307 ... I had no complaints from my vehicle. When I press each gas for a few minutes after a certain time, this smoke continues and stops after a while. However, when I load the gas at certain intervals during use, this cloud continues to emerge, albeit small. I talked to my own master who said that the turbo was missing oil from the felt. In such a case, is repair done? Or should the turbo be replaced? Or more importantly, the only reason for this malfunction is turbom ...?
08.05.2020 17:56 # 2
SDYMZ
Firstly, get well soon. I think the new one of the turbo is 700 TL. Try to repair it first. Any kind of turbo will be removed. If there is no repair, you will get the turbo.
08.05.2020 17:56 # 3
tellotello
Is there a decrease in the oil of the vehicle? Do you check this periodically? Is the color of the smoke coming out white or blue? Has any vehicle overheated recently? When I talked to the master, did he see the turbo master? Before the turbo replacement, it will be dismantled and sent to the turbocharger and checked.
08.05.2020 17:56 # 4
sametbeder
Thank you for your answers. It has been 4 or 5 months since the vehicle took over the gas and the temperature came over 90 and reached the second line during this time. Procedures have been taken on this issue, and the problem of heat has disappeared. If something happened in the meantime, I don't know about heat. When it comes to the color of smoke, the white ... The master looked over the vehicle without removing the turbo and realized that it was missing oil from the felt. He gave information such that it had to be dismantled, but now it is not urgent to force the vehicle. I'm confused. Do you think it is reasonable to pay 400 500 for repair or replace it ?????
08.05.2020 17:56 # 5
sametbeder
By the way, I have never checked the oil ... I have looked at now, there is no reduction ...
