White Smoke Aid Lutven
08.05.2020 16:56 # 1
murat22
Dear Friends, Murat ... I'm joining from Germany, I just got a new member and I have a problem car
08.05.2020 16:56 # 2
murat22
your friends will answer?
08.05.2020 16:56 # 3
tigerland
If there is no oil reduction, smoke is normal. check with the vehicle running, pull the dipstick slightly. press the gas, see if there is smoke from there or shut the exhaust by hand. hold it for a few seconds and leave no smoke, no problem :)
08.05.2020 16:56 # 4
spearo
If there is no oil reduction, the white smoke seal indicates that the gasket is damaged or the engine block appears in the water jackets and water has escaped into the cylinder in both cases.
Is this very dense smoke?
08.05.2020 16:56 # 5
murat22
No, it does not always come, I used the gas, when it comes out, it turns out, I started working today, I looked at the car, while I was looking at the window while driving, I said, I don't see it again. ... teşşekürler ..
08.05.2020 16:56 # 6
murat22
Tessekurler I'll do a test tomorrow, let's see what the result will be, I will write here.
