WHITE SMOKE
08.05.2020 20:15 # 1
seyitunsal
HELLO FRIENDS I ARE WAITING YOUR EMERGENCY AID AND COMMENTS
MY CAR 2007 MODEL 307 1.6 HDİ 90 BG
145 THOUSANDS
CAR MOTOR cold FIRST START PRESSURE IRREGULARLY AND OVER WHITE SMOKE TRIPS AND LIGHT BURNS SMELL enjoying VEHICLE breaking TILL heats up in SMOKE NO to DENR USTA to TAKE I FUEL CONTROL WAS SHORTAGE NO FAN without SAID TURBO repair was RATES BUT STILL PROBLEMS THE SAME ENGINE WANT TO SAY I AM IN BELIEVE TO SEEK I FALAN VEHICLE In Shooting NO ANY LOSS OF POWER WORKS
WHAT WE SHOULD DO IF I HAVE EMERGENCY HELP IS THERE EVERYTHING IS IN THE PRESS, WHAT WAS DONE THAT THAT THAT THAT IT WAS THAT THANKS CryCryCryCry
08.05.2020 20:15 # 2
hzr206
I had a similar situation with me, the injector had come out. If you want to book a carbon clean application, if it is egr or catalytic clogged, it can do it, but if not, it would be beneficial to take the vehicle to a low low mileage, and the injector did not give the error code.
08.05.2020 20:15 # 3
GokhaN
[QUOTE = seyitunsal] HELLO FRIENDS ARE WAITING FOR YOUR AID AND COMMENTS
145 THOUSANDS
I think your problem is still injectors and gaskets
08.05.2020 20:15 # 4
Oktkor
How easy the engine wants it :)
Even if the engine changes, I think that the master cannot fix the problem, go to another master.
08.05.2020 20:15 # 5
seyitunsal
The fear that we changed the oil of the vehicle, the master who asked for the engine to burn oil said so, but as far as I know the oil burning vehicle will emit more smoke when it gets hot?
08.05.2020 20:15 # 6
ggitaristt
WHEN THE MOTOR IS COOLED, THE FIRST STARTER IS WORKING IRREGULARLY AND EXTRACTS THE WHITE SMOKE AND THE LIGHT BURN ODOR IS REMOVED.
I think the top cover gasket .. If there is water leakage to the cylinders, you mentioned the problem.
08.05.2020 20:15 # 7
seyitunsal
As far as I read, I am skeptical of this problem because the oil-burning vehicle always throws smoke, we changed the oil, I looked at its water, I will use it for a while and check which one is missing.
08.05.2020 20:15 # 8
mattex
the same vehicle and the same problem is in my mind, the problem is caused by valve tires, although it is a very cheap material, it is difficult to change and it is expensive to work. It works irregularly for 7-8 seconds because it works because of smoke and bad smell. This is one of the chronic illnesses of 1.6 people. It was a little long but I think I explained the question you asked ..
