white smoke
08.05.2020 16:49 # 1
secur73
friends, I was not getting into my car for 2 days. Something that caught my attention was that white smoke came out.
08.05.2020 16:49 # 2
secur73
NO FRIENDS TO HELP THIS TOPIC ???
08.05.2020 16:49 # 3
falan
I don't know why but you just check the water of the car just in case. radiator may have boiled water.
08.05.2020 16:49 # 4
okan4037
I think blue smoke was not burning oil, white smoke was nothing & nbsp; Maybe it's normal when the engine is cold or it is running out of the sand. I need to see the cylinders.
08.05.2020 16:49 # 5
elsoberano
Check the water level of the vehicle, which may be related to the seal.
08.05.2020 16:49 # 6
Normally, white smoke is a sign that cooling water is being burned. I think you only received this white smoke in the first run. In this case, I think you see that condensed water as white smoke is discarded. If there is no decrease in the coolant level of the vehicle, the situation is quite normal. Reviews
08.05.2020 16:49 # 7
Cmoss06
When the cold engine is running, white smoke is normal, but if it is running when it is hot, check the cooling water level.
08.05.2020 16:49 # 8
turbo27
diesel diesel?
08.05.2020 16:49 # 9
okan4037
xt premium is 99% gasoline:) & nbsp;
08.05.2020 16:49 # 10
secur73
& nbsp; gasoline / lpg I was in the industry today, I checked the master oil, checked the water, said that there was nothing in the car, checked the smoke that came out, there was not much time during the day (some of them burned gaskets or something said, I scratched it), the master said it would be drowned in the smoke ... the water drop showed that the engine was ii ... thanks for the answers ...
