WHITE SMOKE
08.05.2020 21:23 # 1
Pejoant
Hello friends. Have a good night.
My vehicle is 2000 xt 1.6 206. petrol & lpg.
Weather in Antalya is broken 3 4 days. Paso rain. Today, I made my stroll in the city, then came home, while parking the car in the garage, thanks to the light of the stop lights, white smoke was emitting intensely from the exhaust. Is this a problem ? I also use the tool lpg. There is a sequential system lpg. by the way, 2 injectors are in the faulty vehicle. Is it blowing white smoke because it is rainy and the weather is cold? or is there a major problem like gasket? The vehicle does not decrease the water, the oil does not decrease and the performance is good. what do you think could be? I would like to thank everyone who did not hide his thinking and commenting information. And don't get me wrong, I would be glad if only those who knew made comments. When those who do not know about it comment, other results may appear: D thanks Tongue
08.05.2020 21:23 # 2
omerb
Hello, there is also white smoke in my vehicle. I also come across most vehicles on the road. If there are no signs of gasket burning, it is probably due to precipitation. You only say the injector is defective, you say there is no problem with traction. A little strange situation.
08.05.2020 21:23 # 3
Pejoant
[QUOTE = omerb] hello, there is also white smoke in my car. I also come across most vehicles on the road. If there are no signs of gasket burning, it is probably due to precipitation. You only say the injector is defective, you say there is no problem with traction. A little strange situation. [/ QUOTE]
The vehicle was kicking, the idling was falling, there was a problem. I went to the lpg control, the lpg setting was done, the problem has been fixed for a while but the master said that the 2 injectors will be defective. ok it burns too much the vehicle is certain, but I have not seen a noticeable drop in performance. But in LPG, I got 5 people in the vehicle and 2 people got uphill. Maybe the difference is, I don't know.
08.05.2020 21:23 # 4
omerb
If your budget is available, I think you can change the injectors when you have the opportunity. There is no problem with white smoke if there is no water reduction in the vehicle. Follow your water level for a while.
Apart from that, it is something caused by the weather or malfunctioning injectors. The most dangerous of all is water reduction, the burning of the upper cover gasket or cracks in the upper cover, and the cooling liquid entering the combustion chamber.
08.05.2020 21:23 # 5
Pejoant
[QUOTE = omerb] If your budget is available, I think you can change the injectors when you get the opportunity. There is no problem with white smoke if there is no water reduction in the vehicle. Follow your water level for a while.
There is no water reduction but I check. Will it harm the vehicle if I do not change the injectors and get on like this?
08.05.2020 21:23 # 6
omerb
of course it does harm. 4 cylinders of the vehicle. The 2 cylinders are not working properly, there is too much burning / non-burning. Or compression ratios vary. It opens up big problems. I think don't waste time.
08.05.2020 21:23 # 7
ismailkaya
If there is a minimal oil leakage from the valve rings, you can give an example to the combustion chamber. If gas oil is mixed with low oil and put into the storage of the wood miter, when the engine runs out, white smoke comes out of its exhaust, if the oil escapes very little, the smoke comes out very thick, probably in your vehicle, there is no possibility that the white smoke from the valve ring is leaking or it is more likely than the white smoke ring, this white smoke is very dense and more thick than the other. The valve rings may have changed. Here is my research to diagnose what I wrote in the competitor, maybe for some other reason I just guessed
