white smoke
08.05.2020 19:41 # 1
hakao
Gas gauge is not working in the car. My brother got on this car. There was no gas left in the morning. He did not work in the morning. The car worked after a few tries, no problem. Then, while working at idle, we saw that some exhaust came out a little, I don't know whether water or gasoline dropped very little. After that, I closed it and left it in the morning. There was no oil reduction in the vehicle before. In 110 thousand maintenance, I changed the gasket last year to be guaranteed. Do you think anyone knows why he did it? It's not too cold these days, I live in Aydın and it seems like not from the cold. Thanks in advance.
08.05.2020 19:41 # 2
talip206
If there is no water and oil loss in the vehicle, do not be afraid. It is normal for the cold engine to throw some water. If it is throwing water in the hot engine, then it is useful to check. The smoke event will also pass, probably because the vehicle is forced to stay without fuel and this can happen when fuel is used.
08.05.2020 19:41 # 3
hakao
Just like that, there was no problem in the morning. Thanks for the answer
