white scented diesel oil
08.05.2020 18:52 # 1
ilker_ersin
hello 2006 307 1.6 hdi, my problem is that when the engine is cold, when the engine is cold, in a short period of 2 minutes, diesel smell of dense white smoke comes out from the exhaust, and then it stops. Are there any friends with knowledge on this subject?
08.05.2020 18:52 # 2
hatayli
Firstly, get well soon. most likely injectors have a spraying problem. I had a problem with my injector in my previous vehicle. you can connect to the computer and get more detailed information.
08.05.2020 18:52 # 3
ilker_ersin
Thanks for your answer. Does the engine run lightly until the smoke ceased, was it also in your vehicle? After my car warms up and when I run the engine when it is hot, nothing happens, everything is normal. As I mentioned in the title, when the engine is cold, it takes about 2 minutes and everything returns to normal.
08.05.2020 18:52 # 4
hatayli
Yes, when I run it does it occasionally when the engine is hot. If you pay attention to the rearview mirror while you are on the road, you will see again slightly, especially in the evening, in the light of the vehicle coming from the back, pay attention to whether there is smoke. but the best solution is to connect it to a computer and get detailed information.
08.05.2020 18:53 # 5
ilker_ersin
Yes, when I root the gas in the evening, I can notice the smoke from the headlight of the rear vehicle in the rearview mirror. But I thought it was normal because it was a diesel vehicle. In the meantime, let me connect the car to the computer at 236 thousand km in the first maintenance and see what happens.
08.05.2020 18:53 # 6
hatayli
just connect it to the computer and let us know the result.
08.05.2020 18:53 # 7
ilker_ersin
I only had the opportunity to put the vehicle into service. The smoke problem was due to spark plugs. I was informed that it can be broken when disassembling in a place that is difficult to reach and disassemble, but thanks to the skillful master, he dismantled it without breaking it and saved me from much greater expense.
08.05.2020 18:53 # 8
xmen
workmanship, heating spark plugs in total ...
