white led
08.05.2020 19:02 # 1
darklebron
friends I passed the white lede like other friends. I made the dipped headlights and high beams osram nıght breaker unlımitted plus on the subject I shared earlier. How long have I wanted to enter this led business? Let me tell you what I did. I made the plate bulbs white led bulb. The ceiling lights in the back and the front made them white led, and tomorrow I will wear the lighting in my park bulbs tomorrow. good forums
08.05.2020 19:02 # 2
byderebey
[QUOTE = darklebron] friends I passed the white lede like other friends. I made the dipped headlights and high beams osram nıght breaker unlımitted plus on the subject I shared earlier. How long have I wanted to enter this led business? Let me tell you what I did. I made the plate bulbs white led bulb. The ceiling lights in the back and the front made them white led, and tomorrow I will wear the lighting in my park bulbs tomorrow. good forums [/ QUOTE]
Is the sibling interior lighting fading like the original, or is it extinguishing directly?
08.05.2020 19:02 # 3
byderebey
which led you used in ceiling lighting, I would be happy if you give me a link at the back and front .. I am thinking of doing it too ..
08.05.2020 19:02 # 4
darklebron
I do not know my brother as a link, I went to our auto electrician here, he gave me a white led bulb suitable for the model of the car, so I can explain it to me, it is exactly the same size as the original bulb that came out of it, but think only white, my friend, it was really nice.
08.05.2020 19:02 # 5
byderebey
What did you pay for, brother ... How many leds are there in the bidet on the front 3 of them?
08.05.2020 19:02 # 6
darklebron
The total cost me 20 TL, brother. All 3 of them are the same yes, but as I said, you can handle it more cheaply, more expensive or I had it in my mind.
08.05.2020 19:02 # 7
muro_60
When the ceiling lamp is led, the extinction time is extended.
08.05.2020 19:02 # 8
tolga.onal
I also have white leds, there are normal parking bulb-shaped leds in the interior lighting, but when mine is turned off for years, it is not too disturbing but is yours going out completely or is it lightly turned on?
08.05.2020 19:02 # 9
darklebron
The mast closes in me, brother, I haven't encountered a problem like that yet.
08.05.2020 19:02 # 10
Alicilik
[QUOTE = tolga.onal] I also have white leds, there are normal parking bulb-shaped leds in interior lighting, but when mine has been switched off for years, it is a little uncomfortable, but is yours either completely extinguished, or does it remain lightly open [/ QUOTE]
Discard 1ohm resistance or remove from canbus bulbs.
08.05.2020 19:02 # 11
byderebey
I made the white leds on the ceiling, in the trunk, the bidet to the torpedo .. ŞaşkınBüyük gülümseme
08.05.2020 19:02 # 12
Alicilik
[QUOTE = byderebey] I made the white leds to the ceiling, the trunk to the trunk, but I think the fuse of the torpedo was blown out. ŞaşkınBüyük gülümseme [/ QUOTE]
I know that torpedo lighting is with or without tape. One of the fuses under the steering wheel.
