Whistling sound when you press the brake?
08.05.2020 18:26 # 1
ayna
I'm using friends 206+. The car started to sound like a whistling sound. Especially when I press the brake lightly. The sound is cut off too much. This may be the reason. Steel rim is attached.
08.05.2020 18:26 # 2
get your brake discs finished
08.05.2020 18:26 # 3
ayna
Does it come from the front wheel or back? How long are these disks in the bidet? Is the vehicle still normal at 31000?
08.05.2020 18:26 # 4
ayna
So is there any harm? What happens if I don't handle it like this?
08.05.2020 18:26 # 5
ahmet_bjk
[QUOTE = bitter] I think the problem will be solved if you get a soft pad, not discs. Hard pads make sound but do not dust. You have to choose between 2. Probably sound coming out of it [/ QUOTE]
I agree that the pad is unfinished, but it is not a problem making sound because it is hard.
08.05.2020 18:26 # 6
Bugra
When dust enters between the disc and disc, it usually makes sound. and it usually happens after the rain. but it will pass after a while. but if there is a disturbing sound like metal snoring like metal rubbing sound, the pad is finished.
08.05.2020 18:26 # 7
ayna
Can you tell if it looks out or not? It would only come when braking, and now it started to come as it went
08.05.2020 18:26 # 8
mistercasper
I guess your problem is, as friends say, I think I have the same problem, but I guess mine is from discs, I will turn the discs and use them again. .
08.05.2020 18:26 # 9
mistercasper
Look at the thickness of the linings, if it is too thin, it also crows
08.05.2020 18:26 # 10
ahmed206
Get lining spray 8tl. squeeze the pads from a close distance and clean it will change if there is still sound
08.05.2020 18:26 # 11
samet206
My discs are finished, my teacher, with great caution, if the sound does not pass in the long term, your problem from the discs will make the first moment if the vehicle is not used for a while, it passes when the sound gets warm but it does not, as I said.
08.05.2020 18:26 # 12
TuNeR_32
The brake system is the most important safety unit of your vehicle, so avoid the operations such as turning the disks of your vehicle and insert a quality disc and pad. dust sound etc. No, do not wash your vehicle when your discs are hot, do not keep cold water on your discs or the discs will be bent and wobble every time you press the brake.
08.05.2020 18:26 # 13
ahmet_bjk
[QUOTE = TuNeR_32] Brake system is the most important safety unit of your vehicle, so avoid discs such as turning your vehicle's discs and insert a quality disc and pad. My discs and pads were finished. my brakes have improved a lot now and also dust noise etc. No, do not wash your vehicle while your discs are hot, do not keep cold water on your discs or discs will be bent and wobble every time you press the brake [/ QUOTE]
I unknowingly entered a high snowy place when the discs were hot and the discs were worth the snow. the brake pedal was shaking when I applied the brake.
08.05.2020 18:26 # 14
ahmet_bjk
[QUOTE = mirror] Is it understandable when looking outside? It would only come when braking, and it started to come as it went now [/ QUOTE]
it is understandable but you cannot understand if you have not seen the finished and unfinished lining before.
08.05.2020 18:26 # 15
ayna
Let me take a look at someone who knows best. I washed the discs with hot water when it was hot.
