Whistling sound from 206 clutch !!
08.05.2020 17:56 # 1
korkusuz202
Hello friends, when I press my car's clutch halfway, it sounds like a whistle sound ... the master print pad in the industry said the lifetime is coming ... do i need to change ??
08.05.2020 17:56 # 2
qqyyxx
It does my continuity, usually the first time you run it.
08.05.2020 17:56 # 3
korkusuz202
the opposite happens when it first runs, after a while
08.05.2020 17:56 # 4
qqyyxx
then it is increasing in parallel with the heat, it is possible that the pressure pad or the balls that I do not remember the name will originate from them in the gearbox. If the volume of the sound is not high, do not bother, the transmission must be removed. it is good to change the oil. & nbsp; if the sound comes from the gearbox.
08.05.2020 17:56 # 5
samet206
Are you sure it's from pressure not from disks? If the brake is cut to the pressure, the experiment has no connection with degradation if it disappears when you touch the brake.
08.05.2020 17:56 # 6
korkusuz202
Thank you for your comments.
