Whistling sound
08.05.2020 21:21 # 1
saricicek
Hello friends
My vehicle is 2004 model hdi 206. After using the vehicle for a while (like 20-25 minutes) I keep on braking. When you release the brake, there is a sound that sounds like a whistling sound while the vehicle is flowing or plugging in. It doesn't happen in other gears. It does not feel any problem. The sound comes only after pressing and releasing the brake. So when the wheels start spinning, there is sound. No sound while driving.
Thanks for your help
yellow flower 2019-11-15 09:57:36
08.05.2020 21:21 # 2
omerb
Barış Bey, when the drum or discs are heated, metal expands and frictions occur in the linings. Is it such a problem?
Of course, commenting without hearing voice complaints is only a suggestion.
But I heard that sounds like this came from pads and disc groups.
Hope your problem is solved.
08.05.2020 21:21 # 3
saricicek
Thanks for the answer. I thought so too. Cant covers of the front wheels are black. The lining looks like dust. They wrote that the spring expands when it gets hot in one place and it cannot fully perform its task.
08.05.2020 21:21 # 4
saricicek
I added the video of the sound. Thanks again.
[TUBE] rcq4thql-ty [/ TUBE]
08.05.2020 21:21 # 5
As if my teacher probably wore the front discs, the pads had been in 206 das. When my discs got worse, it was complete when I changed the brake disc and brake fluid.
08.05.2020 21:21 # 6
Pejoant
bro, check the disc and brake pads. Either there is a common brand brake pad or I don't see any other possibility of discs.
08.05.2020 21:21 # 7
saricicek
Thanks for your answers
