Whistling sound
08.05.2020 19:46 # 1
debug
Hello. There is a high-pitched whistling sound that I have felt while driving in 4th and 5th gear recently. No 1.4 gasoline turbocharger :) Could the exhaust hole be making from it? Or is it from the gearbox? Could the oil be reduced?
08.05.2020 19:46 # 2
debug
Does anyone have any idea about this sound? :)
08.05.2020 19:46 # 3
okanata1973
Whistling sound Question
08.05.2020 19:46 # 4
exhaust - door seals - glass seals - loose plastic parts can cause this type of noise.
08.05.2020 19:46 # 5
Cyrus35
[QUOTE = sonerkyl] exhaust - door seals - glass seals - a loose plastic assembly can cause such sounds. [/ QUOTE]
I agree. Even the wind entering through the space between the fender can create a whistling sound there.
In addition, the tape does not pick up the motor sound and it makes a high-pitched whistling sound depending on the room speed and throttle.
08.05.2020 19:46 # 6
debug
Now let me say it. A sound similar to the whistling sound is more precisely "vjjjjjjjj": D The exhaust hole is already, but this sound is only when I press the gas in the 4th and 5th gear. For example, it comes at 4 when it does not come in 3rd gear at the same speed. That's why I suspect the gearbox and it is hard to find a "master" in Istanbul. They said "harun in the bostanci industry is very good" for the last press brake and started printing after 500 km.
08.05.2020 19:46 # 7
Karacocuk24
my friend looks like the gearbox is what you say, if you are on the european side, i suggest you go to maslak peugeota
