whistles ...
08.05.2020 18:21 # 1
web_sef
Hello friends,
I have owned 1,4 diesel 307 for 8-9 months. My vehicle started to crow for 2 months. It whistles after 2 thousand cycles. I guessed it as Turbo, I took it to the turbocharger in Tuzla industry,
-My brother said the turbo problem we need to overhaul this.
I said ok, we had it repaired. However, the whistling sound did not stop. Söken biker said there was no catalyst in the vehicle and the sound could be due to this.
Can you help me please? Can the catalyst really make this sound? The catalyst also cost 500 TL. If we put this on, is this whistling sound cut off or is it done for nothing? Does that sound continue again?
Thanks...
08.05.2020 18:21 # 2
Does the whistling sound come from the engine when driving your car or from the exhaust?
08.05.2020 18:21 # 3
web_sef
It definitely comes from the engine. the catalyst treasure is also
Just at the bottom. Let's say we have installed the catalyst or if it is not interrupted.
Because this voice was not there before for the last 2 months.
Thanks
08.05.2020 18:21 # 4
muku
I think it is from the gearbox, control it as a gear, not as a revolution, I think yours is a 5th gear
08.05.2020 18:21 # 5
web_sef
Hello there,
The vehicle starts to sound as soon as 2 thousand revolutions pass in each gear.
The catalyst said master, but if I do this, I will be hesitant if the problem is not resolved again.
I think if it does from straps, but this is not the sound of the strap. The whistling we know is after 2 thousand cycles.
Please help, I was really helpless.
08.05.2020 18:21 # 6
kuscu38
I get past my teacher, a troubled and stressful situation. As friends say, it is likely to be from the gearbox. There was no problem in my vehicle's traction, but there was a buzzing sound, there was a buzzing sound. If you suspect the sound of the belt: open the hood - start the car and let the gas start to gas. Wink
08.05.2020 18:21 # 7
web_sef
What is the price of maintenance in the gearbox, or what will they do, do you know
08.05.2020 18:21 # 8
kuscu38
[QUOTE = web_sef] What is the price of maintenance in the gearbox, or what are they going to do, do you have any information [/ QUOTE]
It depends on the trouble caused by the transmission you call. I had eaten all the gears in my gearbox and found 1260 lira at expense.
then handle the catalyst
look at the latest gearbox, I think "O" is the most costly
