Whirring Sound
01.10.2020 23:33 # 1
rusty
Hi. I just joined you. The problem is: I have a 2009 model 308 vti engine vehicle. LPG size. 90 thousand km. there is a whirring in the vehicle that we cannot find. There were no parts left unassembled and not looked at. This problem was too costly for me. We went to the well-known masters in Istanbul who are highly recommended in these forums. Neither maslak left, neither ikitelli nor the gardener ... They told me that this is defective, this is defective, they replaced the intact parts and could not find them. Now I sell the parts that come out as second-hand at letgo ... the problem is that there is no problem when traveling at a normal speed. for example 3250 dd while driving at a constant speed of 110 km. car. but when the speed increases when the gas is pressed, the buzz begins to come from the front. This whirring is also doing when the vehicle is loaded while going up the ramp. gearbox mounts, air filter and resanor box.egzos, catalyst, fuel pipes, there was no place left untouched, and there was no place left unchanged. If anyone has a problem, I would be glad if they could help. rusty2020-10-01 23:35:39
02.10.2020 21:07 # 2
rusty
God's God, 144 people have read, and the servant of God has not answered.
03.10.2020 14:04 # 3
YK4663
Hello, Is it possible for you to get to know the voice a little more? I have been hearing a voice for the last two days and we found the reason, thank God, it is the same thing.
03.10.2020 16:21 # 4
rusty
[QUOTE = YK4663] Hello, Is it possible for you to know the voice a little more? I have been hearing a voice for the last two days and thank God it is the same thing. [/ QUOTE] The rattle you know is like the vibration of metal. Insulation under the hood is removed. Silicone was squeezed between them, but it did not happen. But certain things make a sound like two metals touching each other and making noise in the increase of loose speed, in short, when the vehicle is loaded.
03.10.2020 16:34 # 5
YK4663
[QUOTE = rusty] [QUOTE = YK4663] Hello, Is it possible for you to know the voice a little more? I have been hearing a voice for the last two days and we found the reason thank God it is the same thing. [/ QUOTE] The rattle you know is like the vibration of metal. Insulation under the hood is removed. Silicone was squeezed between them, but it did not happen. But certain things make a sound like two metals touching each other and making noise in the increase of loose speed, in short, when the vehicle is loaded [/ QUOTE] Automatic transmission?
03.10.2020 18:13 # 6
rusty
Manual
03.10.2020 18:23 # 7
YK4663
The sound you mentioned was also in my vehicle. Automatic transmission is my vehicle. Yesterday, we lowered the gearbox and the flywheel bolts were not tightened well before and became loose as time passed. It sounded like bars rubbing against each other when the car was parked or when I was on the ramp when I was on the gas and pulled my foot off the gas. If you can shoot a video of the sound, we can compare it. Hopefully it benefits your business.
04.10.2020 15:07 # 8
rusty
[QUOTE = YK4663] The sound you mentioned was also in my vehicle. Automatic transmission is my vehicle. Yesterday, we lowered the gearbox and the flywheel bolts were not tightened well before and became loose as time passed. It sounded like bars rubbing against each other when the car was parked or when I was on the ramp when I was on the gas and pulled my foot off the gas. If you can shoot a video of the sound, we can compare it. Hopefully it benefits your business. [/ QUOTE] printing pad changed 2 years ago. At that time there was no such problem. You said the flywheel, but my flywheel was not removed. The pressure is stuck.
04.10.2020 20:02 # 9
talip206
If the sound is faint, check the route of the hood release wire. It can vibrate and hit left and right. I don't know about the 308, but the 206 has a petrol recycling valve inside the right front fender hood. He can hit the mudhole and vibrate from the inside. That part is not visible from the outside without removing the hood. Apart from that, it is very difficult to comment without hearing the voice here. If even the masters cannot listen and find the sound, how can those in this forum help before they hear it?
04.10.2020 20:44 # 10
rusty
[QUOTE = talip206] If the sound is faint, check the route of the hood release wire. It can vibrate and hit left and right. I don't know about the 308, but the 206 has a petrol recycling valve inside the right front fender hood. He can hit the mudhole and vibrate from the inside. That part is not visible from the outside without removing the hood. Apart from that, it is very difficult to comment without hearing the voice here. If even the masters can't listen and find the sound, how can those in this forum help before they hear it? [/ QUOTE] It's the only thing I doubt. Petrol pipes. Same problem because passat owner threw youtube video. Gasoline recycling pipes vibrate. The gas pipes are at the back in the chest area. It's too cramped out of the idea box
05.10.2020 00:20 # 11
bykeskinofk
Hello friends. The buzzing sound is also in my vehicle. 2012 Peugeot 308 1.6 HDI. Probably I don't know how to solve it when it comes to relaxation :) bykeskinofk2020-10-05 00:25:40
06.10.2020 00:38 # 12
muzzy35
My brother has that voice (I did not know the same, but) the vehicle speed is heard around 2500 and above. He tested it, so he said very confidently, I couldn't make the change because they wanted good money, I could not continue until they go, maybe you can be in the distance, maybe zzy352020-10-06 00:41:56
06.10.2020 15:51 # 13
KILIC
Are you sure the sound is coming from the engine compartment? Check the place where these hoporlors are on the front chest. At the same time, there should be screw caps where the chest is attached. Remove those covers and check if there are any screws under them.
05.02.2021 13:03 # 14
cruise05
How much you paid for this transaction
05.02.2021 13:16 # 15
YK4663
The sound problem in my vehicle was caused by the torque converter. It was removed and revised, the traction improved and the sound was cut.
05.02.2021 21:36 # 16
rusty
friends, it's me who opened the subject.
my problem has been solved.
Thanks to drive2.ru.
vti 308 is a popular model in russia.
I found that the problem is caused by the rubber grommet that holds the air filter on the manifold and the rubber grommet holding the filter cover to the rocker. I put it on.
There is no sound.
rusty 2021-02-05 21:49:20
