While the car is spinning, there is a loud noise
08.05.2020 20:08 # 1
Eyup B.
I drew the gold, these caught my eye, could it be the reason? The left side is like a blower.
Right
Left
08.05.2020 20:08 # 2
Narkotik
The axles will change
08.05.2020 20:08 # 3
sevozgur
It may be a zrot. It should sound even where you stop when you turn the steering wheel
08.05.2020 20:08 # 4
teacher, that sound comes from the front panel (swing). the blower is gone. I changed the z rods when changed.
http://www.peugeotmarket.com/peugeot-206-salıncak-sol,pr-63.html
08.05.2020 20:08 # 5
Eyup B.
[QUOTE = sonerkyl] teacher, that sound comes from the front plate (swing). the blower is gone. I changed the z rods when changed.
I just changed the Z rods, the sound was not interrupted. it only happens when turning left, or when parking, while the steering wheel moves in a rotating position. Rot I suspect your head, but you said swing isn't that bellows zrot?
08.05.2020 20:08 # 6
ggitaristt
Bellows axle bellows
It looked like a swing ball joint to me. change 25 lira something ..
Edit: left ball joint
ggitaristt 2017-01-11 20:09:38
08.05.2020 20:08 # 7
Eyup B.
[QUOTE = ggitaristt] Bellows axle bellows
Will ball joint change?
08.05.2020 20:08 # 8
Eyup B.
1st photo tie rod only
I took the swing in the 2nd photo
probably the swing would change: S
08.05.2020 20:08 # 9
ggitaristt
If the swing rubbers are intact, you may not need to change them. swing ball joint is removed. i did so ..
The picture will not be repaired, but you will take it to the gunner, he will make a list for you. have it repaired and rotted.
08.05.2020 20:08 # 10
Eyup B.
We have a bidet rod adjustment or pof estimate how much cost do we eat?
08.05.2020 20:08 # 11
ggitaristt
The rocket takes a total of 30 pounds of stone crack. He will make a list that will look first. rod adjustment after repair again ..
By the way, I did not pay attention to the swing change is not necessary in 307 but I did not know when it was 206 ..
Parts of 206 cheap
I don't know the mechanic at 20 or 100 ..
My 307 single ball joint replacement cost 65 pounds in Ankara.
08.05.2020 20:08 # 12
Eyup B.
Friends went to the Rot balancer, said the swings are finished.
The man changed the swings and the sound was cut off. No problem right now.
I only experienced a situation like this. The master, who changed the swing, struggled a lot and said he was shocked. He did one of them while he was doing the other while he removed the AKS and poured the transmission oil on the floor. Then, by opening the bonnet, they reinforced the transmission oil. I do not know the model of the brand, he said he put the 80 90 model put on each vehicle ..
Do you think it would be a problem to pour the gearbox oil and add it to it?
08.05.2020 20:08 # 13
it would be wrong to add oil on top of our 75w / 80 teacher.
08.05.2020 20:08 # 14
Eyup B.
[QUOTE = sonerkyl] it would be wrong to add oil on top of our 75w / 80 teacher.
Should I not have trouble with the absurd masters? What do you think I should do?
Now I called the master, my car oil said 75/80, he said, it is suitable for every vehicle 80/90 will not be a problem. It is thinner. He said we are putting 80/90 on all new vehicles.
In addition, by removing AKS, not all the oil will drain, right? If it has not been emptied and added 80/90 on it, will the problem arise or will it be confused? For 30 pounds of oil, I would renew it from scratch.
Eyup B. 2017-02-24 11:26:42
08.05.2020 20:08 # 15
Well, looking at Eyüp like this, 80w / 90 gendel truck is used in light commercial vehicles, it is used in some cars, but I don't think it will damage the transmission, but we need to look a little, the oil should be 75w / 80 for our vehicles, when the axle comes out, there is still some oil left in the axle. even check out catrol's site like this
08.05.2020 20:08 # 16
Eyup B.
[QUOTE = sonerkyl] Well, looking at it, the 80w / 90 gendel truck is used in light commercial vehicles, it is used in some cars, but I don't think it will damage the transmission, but we have to look a little bit, the oil should be 75w / 80 for our vehicles, once the axle comes out, all the oil does not drain again. the amount of oil remains. even check out catrol's site like this
It got stuck in my head, so if I took 30 pounds of oil and go away, change it from scratch? If it is trying to change or fight, it will say something will not happen.
08.05.2020 20:08 # 17
No easy to replace, not difficult, there is a drain plug at the bottom. Take the oil yourself for your peace of mind 75w / 80 mobile master, my head is not comfortable, change it
