Which tire size fits the peugeot 106xr? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 16:14 | # 1 |
SevkeTSeneR |
| 08.05.2020 16:14 | # 2 |
I think 106 gti rim: D: D
| 08.05.2020 16:14 | # 3 |
Yes this size will be the most beautiful gti rim ...
| 08.05.2020 16:14 | # 4 |
I am fixing 106gti a not because it can be for 14 inc 306 gti, but both of them are very hard-to-find rims. I also had a friction problem.
| 08.05.2020 16:14 | # 5 |
SevkeTSeneR |
You say 195-45-15 does not rub, so the 195-50-15 surge did not let me put this size tire on the other vehicle.
| 08.05.2020 16:14 | # 6 |
195 50 15 lasts but 195 45 15 does not rub.
| 08.05.2020 16:14 | # 7 |
SevkeTSeneR |
[QUOTE = HeRo1727] 195 50 15, but 195 45 15 does not rub. [/ QUOTE] understood my brother will buy tire again & nbsp; :)
| 08.05.2020 16:14 | # 8 |
I have a GTI rim 185/55 / R14. & nbsp;
| 08.05.2020 16:14 | # 9 |
SevkeTSeneR |
I bought 195-45-15 tires, this time you need to get rim diopter flange without the flare, this rim is not mounted.
| 08.05.2020 16:14 | # 10 |
what was your original rim and tire size? also no need for flans, I think logically go to another tire
| 08.05.2020 16:14 | # 11 |
SevkeTSeneR |
Original of 13t.
| 08.05.2020 16:14 | # 12 |
sedataksu |
[QUOTE = ShekiL.GTİ] 13t original. [/ QUOTE] What is your original tire size.
| 08.05.2020 16:14 | # 13 |
SevkeTSeneR |
I think 175-65-13
| 08.05.2020 16:14 | # 14 |
sedataksu |
195 * 45 * 15 will fit the tire. But the offset of the rim that you will use is important. Because the sidewall width increases in this tire, the tire will be closer to the inside of the wheel, but it may rub the cheek.
| 08.05.2020 16:14 | # 15 |
SevkeTSeneR |
| 08.05.2020 16:14 | # 16 |
sedataksu |
Look at how many ET * writers wrote in the rim. OFSET (ET) |
| 08.05.2020 16:14 | # 17 |
SevkeTSeneR |
When I look inside it says 35 but I just don't know what it is 35.
| 08.05.2020 16:14 | # 18 |
sedataksu |
When I look at [QUOTE = ShekiL.GTİ], 35 writes only I don't know what that 35 but. [/ QUOTE] If 35 is the meat value. It is 15mm outside. When the 175 cheeks are 195 in the original, you increase 10 mm from the right and left. I think it would be a try. I am sorry that I did not like entering gas.
| 08.05.2020 16:14 | # 19 |
SevkeTSeneR |
Thank you very much. I already have a rim tire. Let's see.
| 08.05.2020 16:14 | # 20 |
yeditepely |
When I look at [QUOTE = sedataksu] [QUOTE = ShekiL.GTİ] I don't know what it is 35 but just 35. [/ QUOTE] If 35 is the meat value. Pegout's wheels are usually 20 offset. When it is .35, the rim is 15mm outside than normal.If you do 175 when the cheek is 195 in the original, you increase 10 mm from the right and left.I think I would try it.No need for a flange.It will not touch the inside.I think the car is not too flat, I think it does not touch the outside. If you are going to get new, I would be sorry to not be at risk to take this risk. [/ QUOTE] as the meat value rises, the rim is whisking out. For example, we will only look at the offset value while buying the rim.
