WHICH TAPE DO YOU CHOOSE (PIONER)
08.05.2020 17:56 # 1
berkejack1
http://www.sahibinden.com/ilan/alisveris-elektronik-arac-elektronigi-pioneer-6350-usb-kart-girisli-cd-kumanda-hediyeli-kapinda-ode-63615038/detay
http://urun.gittigidiyor.com/garaj/pioneer-deh-4550bt-usb-girisli-oto-cd-mp3-calar-91490197
WHAT DIFFERENCES BETWEEN THESE 2 PRODUCTS
WHICH YOU SHOULD CHOOSE
WHY IS THAT?
CAN I CONNECT THIS COMPONENT TEAM WITHOUT THE AMPLIFIER?
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-hoparlor-jbl-gto-6508c-16cm-komponent-takimi-kampanya-133457064/detay/
08.05.2020 17:56 # 2
Alicilik
You run the condensate sets with tape, but after a certain sound level, you can burn the tape outlets.
It is very good in two tapes. 6350 from 1-250 years old 4550. 4550 has bluetooth plus 6350 has Sd card plus
It also has 6350 3 RCA outputs and 4550 2 outputs.
08.05.2020 17:56 # 3
berkejack1
I ordered 6350, now I have to get the door speaker that I will manage for a while, I should get my job in the amphitheater, I will get the amplifier in the future. I will buy a good quality amp for now, I changed the tape for now which one do you think I'll take
http://urun.gittigidiyor.com/garaj/jbl-gto6528s-180watt-16cm-slim-hoparlor-78766105
http://urun.gittigidiyor.com/garaj/jbl-gt6-6-16cm-hoparlor-tweeterli-78766014
the http://urun.gittigidiyor.com/garaj/jbl-cs-6-16-cm-koaksiyel-hoparlor-2-yollu-135-w-91394680#product-informatio
Can you tell me why by difference?
08.05.2020 17:56 # 4
Alicilik
Don't spend a lot of money if you're going to improve the business later.
Take the cs6 is late but if you say I will use it for a long time, I say buy gt6 is better quality.
6528in rms value can tire the high tape.
08.05.2020 17:56 # 5
samet206
Both of them are nice products but 6350 is better in terms of design. but a very fun device in terms of animation screen ...
08.05.2020 17:56 # 6
berkejack1
My brother, I stayed together very much, whether I should compensate or coaxial, or I have 2 products left.
this coax: http://urun.gittigidiyor.com/garaj/jbl-gto-638-16-cm-coaxial-hoparlor-91629103
this compenant: http://urun.gittigidiyor.com/garaj/jbl-gto6508-16cm-mid-takimi-new-model-sok-sok-91124268
The prices are almost the same, but I don't have an amp right now. I want to see my work in the future.
08.05.2020 17:56 # 7
samet206
I think that it doesn't give a nice taste without compenant amphitheater. You can handle the situation with a nice speaker. So my advice is easy in this direction ...
08.05.2020 17:56 # 8
berkejack1
Now I am looking to do so I am thinking about setting up a jbl set, but they say jbl s compenant is not good.
08.05.2020 17:56 # 9
Alicilik
[QUOTE = berkejack1] I am looking to do so now, I am thinking of arranging jbl set but they say jbl s compenant is not good.
Who says brother is not good? What good are they saying?
08.05.2020 17:56 # 10
berkejack1
they praise infinity and hertz and they regret it when they bought jbl. only the amp and component remain
I think infinity component (90rms) and xetec 90.4 amp. Bidet soundmagus c90 has room 90x4 prices 30-50 tl playing.
or
I can put jbl kompenant (70rms) and mg audio 80.4 or one of the amps above.
I found second hand jbl 75.4 for 160 lira but I can not trust it was used for 2 years.
08.05.2020 17:56 # 11
Alicilik
Of course I used both 16 and 13 cm likes better than jbl of infinity, it sounds really good but 2 ohms they get habeirn. They are very loud and do not come to work for a long time. It is necessary to listen for 1-2 hours in medium volume.
The most critical points of the Hertz are the tweeters burning very quickly.
Cut out for JBL sub-sound systems.
08.05.2020 17:56 # 12
berkejack1
Never mind Hertz, I will think of it as infinity or jbl compenant system.
You said to me that instead of replacing the two in one amp, use mono separate stereo separate amp, I told this to a plumber, you said, I would lift your battery. I was going to buy mono in a single bass and 30 cm.
08.05.2020 17:56 # 13
Alicilik
[QUOTE = berkejack1] Never mind Hertz, I will think of it as infinity or jbl compenant system as infinity is on my mind.
We connected 60Ah 206 to 4 * 80w rms amp and 1 * 300w rms mono amp. With 1.5 farad capacitor
JBL 6508c
Pioneer 75w rms oval
2 * 300w rms pioneer bass (double bass single cabinet.
We listened to it like how the plumber is like he is wearing a L7 in the car.
08.05.2020 17:56 # 14
EmSul
The fact that the infinities are 2ohm only makes a difference in terms of supply-connection. There is no approach to listen for a long time at high volume. It is completely related to the setting.
Hertz or any brand, again the burning of tweeter or any other element is also related to the setting and connection error, how many years have I done this work, I have never had such a problem.
2 or 3 way coax, as there will be adjustment and feeding difficulties in use without amphitheater. The speaker is more suitable, even coax than using an entry level mid kit. it gives better results even if it is used in an amp.
With proper connection and setting, no speaker will neither listen to the amplifier nor the tape. There is no baseplate. You can also connect the 1000rms subwoofer to the tape. In addition, the fact that the amphitheater is old is not a reason to increase their malfunction.
08.05.2020 17:56 # 15
berkejack1
I had something in my mind from the first
4x80 rms stereo amplifier
jbl 6508c
I'm connected to the pioneer 6995s
Buy 400w mono amps in 1
pioneer ts-w-310 was to connect 400 rms bass. I thought something like this later on
4 channel amp
I will connect ovals to 2 entrances, I will bridge 2 entrances and give bass.
5 channel amp
jbl component
pioneer bass
I had ideas such as connecting pioneer ovals.
08.05.2020 17:56 # 16
EmSul
[QUOTE = Recipient] [QUOTE = berkejack1] Never mind Hertz, I will think of it as an infinity or jbl compenant system.
JBL 6508c
The plumber you went to was someone who tried to do the job properly. Of course, the player will be connected, maybe it will satisfy the user. 12v and 60amp. If it is taken, it means a total of 720 watts of power. It will not be able to feed the batteries anyway. You don't have as many amplifiers as you want. No 300rms. Connect 30000rms. You can get enough of your feed. Corresponding to the power, this is a system that can be with a battery of 60amps. Suitable wiring and other losses plus using a 1-capacitor capacitor considering the condition of the battery only provides a healthier operation, but not a condenser.
08.05.2020 17:56 # 17
EmSul
Finding 5 channels literally in stereo + mono (i.e. ab + d class) is a bit difficult prices, it is expensive.
08.05.2020 17:56 # 18
berkejack1
my car 93 model corsa b is a bit old.
I thought of something like mono.
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-amfi-autosound-mono-475-watt-bass-amfisi-132588176/detay/
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-hoparlor-subwooferin-babasi-pioneer-ts-w-309-d4-17155281/detay/
this is the first set in bass this is the second set in stereo
compenant
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-hoparlor-infinity-ref-6530-cs-16-cm-mid-bass-takimi-component-124259413/ detail/
or
http://urun.gittigidiyor.com/garaj/jbl-gto-6508c-16cm-compenant-takimi-murtas-urun-93322296
oval
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-hoparlor-jbl-gto-938-oval-3-yollu-6x9-coax-hoparlor-300-w- 100-rms-134034103 / detail
or
http://urun.gittigidiyor.com/garaj/pioneer-ts-a6995s-600w-oval-hoparlor-91835561
I thought of a solid amplifier of 90x4 rms or 80x4 rms. I also buy a capacitor, but I do not know which amplifier my car is small, I do not know the sound that will satisfy me anyway, I have just started this research for the last 2 months. 2 amplifiers made sense to me from the first, but now I have a problem, one needs additional battery for the second one, one says, one warms up the single amp, you can't listen.
08.05.2020 17:56 # 19
EmSul
I would like to respect any of those who say it. 2 amphitheater 2. For the need of the battery, the 2 amps you attach and the power of the speakers you connect are important and I have given an example above how to calculate this. I would say that there is not much needed in a small and hb vehicle such as my personal opinion. The amplifier can be For-x x-54 or Pilippo po-970 or Jbl gto-1004. I think it will be enough for you.
08.05.2020 17:56 # 20
berkejack1
pilippo po-970 is not a thing, I buy it today, I have 2 jbl ovals and a kicker bass.
This is my Pioneer Deh- 6550SD confirmation.
Page : / 2
