which stops should I use?
08.05.2020 17:06 # 1
impact
I think make the original or the inside of the transparencies black :)
08.05.2020 17:06 # 2
Barut
I think the original stops seem better.
08.05.2020 17:06 # 3
hsnsnl
The taste of the original is another or use the stops of the 2006-7 model :)
08.05.2020 17:06 # 4
GokhaN
If the original is a good alternative, it is black based, except for the ones in the pictures.
08.05.2020 17:06 # 5
simurg
Put the original stopper out of it, there will be no back wipe it, it is obvious that you put it in the original, you have a banana medicine, but it is not the original pug of the pug.
08.05.2020 17:06 # 6
elsoberano
original better I wanted to remove the transparencies and install the originals someone cracked & nbsp; i guess something was put on top of it or else I would go back to the original. elsoberano 2012-10-27 11:14:44
08.05.2020 17:06 # 7
fatihgg
I think my original brother is more beautiful.
08.05.2020 17:06 # 8
fexzi
No wonder the original:) & nbsp;
08.05.2020 17:06 # 9
blinddark
I think black is black, but I do not know if it is good to see and be seen because of the security of the drought. perfectly compatible
08.05.2020 17:06 # 10
volkan22
If your brother asked me, the original plug & nbsp; or darken the interior of the sefain because the black vehicle looks beautiful, but the black one is very black. contrived stands & nbsp; and & nbsp; it is not very clear at the stop lamps ...
08.05.2020 17:06 # 11
aknard
Using the jet black is also your choice :)
08.05.2020 17:06 # 12
tilbe307
The original is always better and also looks very bad on the wiper & nbsp;
08.05.2020 17:06 # 13
svgkhn
The original tabi looks even more pleasant.
08.05.2020 17:06 # 14
tigerland
originals are better in myself & nbsp;
08.05.2020 17:06 # 15
EErgul
I say use the black inside the stops right now
08.05.2020 17:06 # 16
horoz72
better than the original
08.05.2020 17:06 # 17
caster21
I put it in the complete body kit and use the bottom ones. Otherwise, the front side has been unbalanced and the classic is unbalanced.
