Which sports spiral should I wear?
08.05.2020 20:46 # 1
Gurhanm
Good afternoon days ...
so to speak, I travel like a stork, my wheels are 16 '' rc wheels which do you think is the most suitable sports coil spring? Is there a brand you can recommend other than Eibach? Between the rubber fender, 5 fingers are very comfortable and the circle of friends is also kidding :) I am waiting for your suggestions, thank you in advance ...
08.05.2020 20:46 # 2
Kerem207
Hello eibach I have 4 cm sports springs. If you think of swapping with original springs, we can talk.
08.05.2020 20:46 # 3
RP393
You can drive those rims with 5 cm. I have an ultra racing 5 cm spring, 195/50/15 gti rim.The space between 2 fingers (1.6 gasoline engine)
If you are not someone who uses your vehicle gently and pays attention to the pit, do not infect 5cm. You can rate the springs nice offer in your friend. RP393 2018-02-22 20:37:52
08.05.2020 20:46 # 4
Gurhanm
1.4 in my car, they say that there is not much difference in 3.5 cm.
Are you happy with ultra racing bro? 195/45/16 tire size too.
08.05.2020 20:46 # 5
RP393
[QUOTE = Gurhanm] 1.4, they say that there is not much difference in my vehicle, 3.5 cm in my vehicle, since the engine is small, I am someone who pays attention to the potholes if the 2-finger remains between the fender rim, the offer is nice, but the springs of the vehicle 207 are different as far as I know.
Yes, I'm glad, the front friction is rubbing, but it's not a problem since it's flexible. Good handling, softness. The tab doesn't do tapping either. If you want to buy cheaper, you can buy apexi brand (bright yellow) springs in the market. Stay away from the red one, it is no different from rebar.
08.05.2020 20:46 # 6
Gurhanm
bow is an important part and I do not trust apexi. whether wearing a 5cm or 3.5cm spring ...
08.05.2020 20:46 # 7
RP393
[QUOTE = Gurhanm] bow is an important piece and I do not trust apexi, I think it is better than a coil coil-ex, but I was researching ultra racing. I think it has a price of 250 TL. the motor is 16`` rim with a 5cm or 3.5cm spring ... [/ QUOTE]
Well, the subject is a bit of a conundrum, I have never found an example. When I put the original 5cm side by side, I think it will sit on the car sump, I thought it didn't sit the sports bow was half the size of the original. As a result, hardness and kurtosis may change according to the brand.
If you get ultraracing, I guess there will be a 2.5-finger gap. Since your engine is a little lighter.
Let me write when I think of it, to make sure that it does not make sound when it receives the springs, be sure to attach a soft silicone hose to the pods from the top and bottom. Let such a sweet hard hose pass. It becomes a garden hose, but only from its soft. RP393 2018-02-23 08:45:21
08.05.2020 20:46 # 8
Gurhanm
Thank you very much for your comments, I am going to buy halal, ultra racing, I think 5cm by the way, the bows are blue, I think there are no color variants like abi apexi 😀
08.05.2020 20:46 # 9
RP393
[QUOTE = Gurhanm] Thanks for your comments, thank you very much for your comments, halal, I will buy ultra racing, I think 5cm by the way, the bows are blue, I guess there are no color variations like ape apexi 😀 [/ QUOTE]
Thank you. Yes, take it from a blue reliable place. Unfortunately, everything has an imitation. I hope it is good.
08.05.2020 20:46 # 10
Gurhanm
God bless my brother thank you ...
