Which master is right? Did my car burn gaskets?
08.05.2020 19:56 # 1
mesut207
Guys, my vehicle, which I showed to 8 different masters, was made with 2 different diagnoses. It will be a little long, but let me write the item and ask my questions. First of all, I am someone who gives maintenance before km comes, but I am not someone who looks at car oil. My car is the Peugeot 207 st 2011 model. The 1,6HD. I came a long way about a month ago, went to work the next day. 250m to the house. I stopped the vehicle while getting up in the lights while I was left. When it started immediately, the temperature indicator made a ceiling for seconds and dropped to 90. I looked at the water at the gas station 200m away. There was no water. I put 4lt of water. I called the master, check the water every now and then, let's see. I checked for water reduction for 2 weeks. I saw that there was very little water reduction in a total of 40km of work / home distance. (Up to 10ml daily.) I showed it to the master because I will go on a long journey again. He looked at the water, listened to the engine and said, "Gasket can be burning, you go controlled, when we arrive, we will look at this together with the maintenance of km." said. After 400km of long roads, I saw 1 liter of water and a little “water like institution” like water exhaust. I called the master again, whether this vehicle will return, he will return. 200km. I traveled on vacation; half a liter of water decreased. 400km. when I came back there was again 1 liter of water reduction; however, the water in the water bowl had turned black. It was not oil, but again from the institution. The institution was homogeneously dispersed with water, black like engine oil. My master; The engine burned out, said the engine top block will be ground. While coming to this opinion, he applied the following methods. 1) Filled the water container to the highest level. He started and closed the vehicle 3-4 times; there was an overflow from the water container; he said because he made air from this engine. 2) Black said it was related to the gasket burning. Then I showed it to 7 more masters. 2 of them; he saw a small fracture in the "oil cooler" of the car. Saying that this may be the reason for the decrease of water; They said that it was unreasonable to make a rectification immediately, it would be better to change it first, clean the chemical and all pipe hose etc. and then test it on the road. They even had anti-theses against what the first master said. 1) The air coming into the water container may be from the pump and is normal. 2) They said that the black institution could come from the hoses because the vehicle was dehydrated, this is normal. The current status; There is no more soot in the water container, but for a week, 0.5 liters of water decrease between 40km of work / home. So the amount of auction has increased. Which master do you think is right? Does it make sense to give the vehicle to the competition immediately? At the end of this process, I am likely to be tempered by the car; Is it a very serious job to grind this engine top cover, which they call reclining?
08.05.2020 19:56 # 2
Welcome to mesut first. As the second master says, there is oil mixing in the water from the oil cooler, as I think the oil cooler is different, as the second master says, check the change again. The engine is not a big problem after being a good master of boring, but it is a bit costly because it is diesel. A process of around 150-200 tl, which is called cover grinding, keeps the workmanship high.
08.05.2020 19:56 # 3
madblueblacksea
If the missing water does not flow out or the most dangerous is not mixed with the oil, it means burning the gasket. If only oil is in the water, you can concentrate on the oil cooler. It may mix from the rising oil pressure due to engine compression to the water from the coolant ... (I personally experienced it myself, it was mixed with the water from the coolant gasket due to the pressure increase, but the conditions improved when it returned to normal, I changed the coolant now, there is no problem) You are very likely to think and burn gaskets. If there is no air in the system, there is no bubble from the reserve water tank. Check it out when you run it in the morning. Considering that the gasket is burning, you will have a total cost between 800 and 1200 TL. This does not have a negative effect, but it is very important to use a suitable cylinder head gasket after the cover is ground. After the cover is grinded, the combustion chambers become smaller in volume and the compression ratio increases. You can get the information of this from the original parts dealer or the recruiters. Cylinder head gaskets are not standard. Ask the master where the water goes ....
08.05.2020 19:56 # 4
mesut207
@sonerkyl and @madblueblacksea
Thanks for your comments. I did not understand much of these issues, so I took the tool to such masters and I am still in a dilemma. I forgot to write madblue reminded me.
There is no water flowing out of the vehicle. My first master said that it could not be seen because it exited the exhaust.
The masters who said that they originate from the oil cooler saw traces of water drop in some parts next to the oil cooler. And he said that it could evaporate with high heat, so it couldn't be seen.
What I was wondering was that when the water pot was an institution, it was no longer an institution. So is this institution a situation that can occur with gasket combustion? And yes there was no oil in the water bowl. Its appearance was like oil, but the soot dissolved homogeneously into the water as if it had been mixed with the mixer.
Let me quote, they said 1500TL. I am not in money, only when the engine is touched, my enthusiasm will escape from the car.
Let me admit, I wasn't expecting such a quick answer, so let me ask another question.
My first master is the Ford master. I used ford for 6 years and he did all the maintenance. I think this vehicle engine and the ford engine are the same, so if I give it to the first master, should I do it wrong or should I find a Peugeot player?
Thanks already
08.05.2020 19:56 # 5
mesut207
Hello again guys. I had the car repaired today and I said let me write the results here.
Water leak detected in 2 places.
1) The o-ring on the lid of the water container is deformed. Though most likely, this is due to the fact that I have been doing dozens of times because the vehicle is constantly losing water. So this is not the real water reduction. Because after changing the cover, the water continued to decrease slightly.
2) The honeycomb part of the oil cooler is crushed. And I don't know how many bars of water from the water container, water gushed from there.
The interesting thing is that this place called honeycomb was crushed by the vibration of what it used to say in the car before, but what the master said "this is not an important part, but the protection sheet".
In short, be you, consider the condition of the parts called junk that touch other parts.
Both parts were changed, mileage was maintained. However, 20 km was tested in the final, again, there was water reduction. Master said this was normal the first time. Because it has completely drained the water, put it back, while operating it at idle several times, it has operated the thermostat and there may be a decrease due to this thermostat. He said that the healthy test was to add water after coming home and after the car had cooled down, then to chill and look after using it that day.
This part of my mind freaked out. I don't know if the guy got rid of it. I will test and report again at a suitable time tomorrow. Perhaps, at this point, it would be the answer to this question.
I couldn't find how to add a photo here. Otherwise, I could write shorter.
08.05.2020 19:56 # 6
themurat54
Sir, first of all, get well soon. I did not read the whole article. Thanks to an apparatus that the gasket of the car does not burn, the masters can learn. It inserts this apparatus with blue liquid into the reserve water tank, if this liquid turns yellow, the gasket is burnt. If there is no wetness under the car, there is a very high potential for gaskets and negligence. Again get well soon.
08.05.2020 19:56 # 7
madblueblacksea
Even if the air is removed after the water is completely discharged, air can still remain. Use a few times to the fan on temperature. Don't forget to put the heating on hot.
08.05.2020 19:56 # 8
mesut207
Let me write the last situation and give information after a long time. I last traveled 5000km after replacing the last oil cooler. There is still a water leak. However, this leak; It occurs when I go up to 150km / h. When I use it at 100-110km speed, it requires only one tea cup every 2 weeks. The institution, which is like the exhaust institution coming to the water container, is over, it no longer occurs.
The main problem is when I open the lid to put water in the water container (I check it before getting in the car in the morning); With a great air pressure, the water goes up. Therefore, I can not add to the water container, although the water seems low.
In the past, I could not say that the gaskets were burned because the hoses were soft. However, since I have now changed the lid of the water container, there is no water and air loss from there, the air inside cannot come out and the hoses are now hard like stones. This indicates that it is burning gasket, I think.
I keep using it because there is no problem because I do not enter the traffic for a long time.
Normal maintenance time after 5000km I will replace the seal.
Hopefully it is only on the gasket.
Worse; crack in the cylinder head
Worst of all was cracked in the engine block.
I guess I'll write it 4 months later.
Greetings to friends who are interested again.
Now I will ask for another help in another title :)
08.05.2020 19:56 # 9
Peugeot35
First of all, drain the water in the radiator and add new water to remove the air. try it like this.
To say that the gasket is burned immediately, you have to do the previous checks by checking the hose inlet and outlet points manually and checking the blind spots with a mirror to see if there is a water leak. water can make marks on hoses.
if you think the gasket is lit;
1. Water is significantly reduced with every ride.
2. mix oil into water or water into oil.
3. Throws water out of the exhaust.
Discharges white smoke from the 4th exhaust.
The 5th temperature always makes the ceiling.
The 6th traction falls as if someone is holding the car.
if there are such symptoms, the gasket is burned.
Of course, the test is performed when the gasket is not flashing. Do not touch the motor without testing.
industry masters are hungry, even if someone is gnawing. they even take out unusual things.
08.05.2020 19:56 # 10
mesut207
[QUOTE = Peugeot35] My teacher first drain the water in the radiator, add new water and bleed it. try it like this.
Article 1: there were first times; but it turns out that the lid of the water container is broken. After that, there was no such water reduction.
Article 2: There is not oil in the water container, but "soot like exhaust soot" has formed after 1000 km. It consisted of speeding up to 150km. No more because I didn't go so fast anymore.
3ve4. item: I checked a lot, they don't happen.
5.No heat. Sometimes it goes up to 90 in heavy traffic but it does not exceed 90. I am not someone who has been in traffic for hours though.
Article 6: There is no problem with traction and fuel.
I saw that test on the internet, but I could not find where and how much money.
Currently there is only a solid air pressure in the car. Hoses are hard. I put as much water as tea glass in 2 weeks. But I see the leak from the container itself. Especially when I speed it, it is missing from the black cap. If there is no speed, there is no kidnapping. In short, the symptoms are not gaskets, I think it is gaskets because of that air pressure.
08.05.2020 19:56 # 11
mesut207
I forgot the air of the radiator. I told the master who changed the oil cooler, it hadn't been there. No, the air had gone wrong. I will do it myself if I knew how. Let me make it happen at another master.
08.05.2020 19:56 # 12
Oktkor
There is no self-confidence and a lot of knowingness on our top. I say, let's take a look at the fiber properly, no, we'll see it like this, and we will lift the fiber with extra expense after two days.
08.05.2020 19:56 # 13
mesut207
[QUOTE = Oktkor] There is no self-confidence and a lot of awareness on our top. I say, let's take a look at the fiber properly, no, we'll see it like this, and we will lift the fiber with extra expense after two days. [/ QUOTE]
Yes, you are absolutely right. I can not explain my problems to them.
Now let me approach it a little philosophically.
As an adjective we call it "repairman", that is, the person who repairs something that is broken. This is the main task of the masters.
However, friends generally; They say we can disassemble it and add a new one. Well, technically it is not called repair.
Authorized service is already doing that job. My purpose for you is to see if it can be repaired rather than cheap, if you can, straighten that piece if possible. Okay, if not, let's change.
I'm not a pintiness, and vice versa. But maybe it is about my engineering formation; First, let's find out what the problem is, I did it wrong, it broke down, did it end up, something electrical, etc. etc.
Let's say you changed the part, but I made the same mistake and broke it again. Isn't it a pity?
We do not manufacture most of these parts. Why should we give the national fortune to the foreigner of the hand?
So I'm in the other dimension of the event.
Don't think backwards; I have tremendous respect for the mechanics. I even have a tremendous respect for the master from every industry that makes money with manual labor. And I am more arrogant than ever before.
But in general, I do not experience the communication problem I had with repairers with any other master.
Even if something is broken at home, I will not go after the authorized service, I will take it to the normal master first. Let the small trades make money; I also say I will not throw my money on the street. I have never had any trouble other than the carpenter.
Regards, my ego.
08.05.2020 19:56 # 14
Oktkor
[QUOTE = mesut207] [QUOTE = Oktkor] There is no self-confidence and a lot of knowingness on our top. I say, let's take a look at the fiber properly, no, we'll see it like this, and we will lift the fiber with extra expense after two days. [/ QUOTE]
Regards, my ego.
I think the same way. They even decide the breakdown upon guess. No need to connect to a computer and look at the code. What happens to our cars. You're getting out of the car. Then, once the car enters the industry, those who cannot correct their waist again come to the market. In the end, the job is working for the dealers, just because the 15-pound part problem could not be solved, we leave the car to the gallery below 2 3 thousand.
08.05.2020 19:56 # 15
Peugeot35
[QUOTE = mesut207] [QUOTE = Peugeot35] First of all, drain the water in the radiator, add new water and bleed it. try it like this.
When the engine is cold, that is, after starting the car one day, run it only if the water tank cover is open, if the water does not rise immediately, there is no problem. If there are no problems I mentioned, the gasket was not burned.
I had this gasket test done in my previous car. When I was in the repair shop, he brought a master and made him look. I don't know who did it. I gave 10 TL.
but if the institutions you mentioned in the water radiator are many, this is a sign that there is a big problem.
the Peugeot 207 st 2011 model. 1.6HDI . If you have a car, I wouldn't recommend you have it done somewhere other than its service. 3/5 whatever it is, be it guaranteed to be more reliable and let me know that I had this engine built in this service.
Peugeot35 2017-03-13 16:07:10
08.05.2020 19:56 # 16
mesut207
I accept all the problems related to the radiator, my only concern is not to start the engine. But there seems to be nothing to do.
When I open the water container when the engine is cold, the water is loading with pressure air.
I said, let me go back yesterday and get the radiator air. I entered a different master. When I said okay, I explained from one side to another. Then he said not to deal with it, he looked at himself. Gasket said this passed. He put his classic hand into the water bowl, said, let go of the gas. He said that he could suck and get well.
I would also find the places where the testers did, they said in the industry there was no.
I was constantly tired of going to the industry, I was bored. Hard jobs.
08.05.2020 19:56 # 17
sdttn
Run away from the master who calls the top cap directly without doing a compression test.
If you open the robust cover and process it to such master, both your wasted money and the life of the motor will be shortened at the end of the process.
08.05.2020 19:56 # 18
zerzevat
Hodja, the color of the water is ok .... Have you ever looked at the color of the oil? When the water mixes with oil, it becomes golden yellow. oil starts foaming. so much so that the inside of the cap, where we put the oil from the top, turns yellow inside the engine.
If you continue like this, the engine will be lean and somewhere to take out the arm.
Brother, we added and added water like this ... and then we made the top cover ... but after a couple of days we removed the arm, we replaced the complete engine, it was his negligence ... but ...: (((The cost was also the cover for me. The top cover. cover of mind: ((
08.05.2020 19:56 # 19
mesut207
Years later edit:
I believed that after the famous colored test had the engine burned gasket and took it to its own master who said the first day. But I used it comfortably for 6 months (edit again: now I look exactly 1 year ago).
He opened the engine top cover and again showed me a notch not as big as a pinhead, as the master said from the very first day.
He took care of the car in 2 days.
On the other day, I solved the electric steering problem that I had opened on the other topic.
Wow it's been 2 years.
mesut207 2019-05-30 21:57:09
08.05.2020 19:56 # 20
Time passes like water, hodja. I'm glad your problem has been solved.
Page : / 2
