which Lpg Kit?
08.05.2020 15:29 # 1
dinoco
As friends are known, I have 206 xt gasoline .. I don't think to install LPG ..
but I have one of the 97 models of carina e for one, I bought it from an old uncle from the first owner of 80 thousand km 2.0 16v and no lpg installed. I want to install LPG to this .. I definitely want to install a sequential system. I am waiting for your ideas. vehicle steel manifold.
08.05.2020 15:29 # 2
boraa
Why don't you get LPG for 206? Question
08.05.2020 15:29 # 3
anil307
If you don't say high cost, I can recommend brc
08.05.2020 15:29 # 4
dinoco
cost is not important ..
I don't have a 206, the vehicle is automatic and very little used .. 60 thousand km of a special vehicle .. as I said, there is not much disturbing fuel ..
but I will wear it to carina e .. every lpg kit (tube :)) has brand and model .. i want to learn this
08.05.2020 15:29 # 5
anil307
90% of commercial taxis, brc 10% wears prins so I say to you
08.05.2020 15:29 # 6
dinoco
This is a brand that is expensive.
or Cem master atiker or what about the other brands. Dinoco 2011-05-28 13:40:13
08.05.2020 15:29 # 7
The brand not Landirenzo.
08.05.2020 15:29 # 8
F-Eren
I also read very positive things about the teleflex gfi, but it was said to be high in price :(
I think brc prins and teleflex are the best brands in this business.
08.05.2020 15:29 # 9
dinoco
I'm investigating tskler eren
08.05.2020 15:29 # 10
Kemanyak
Lovato plug seamlessly. It didn't show me my fault light once.
08.05.2020 15:29 # 11
ose
bmw ciler puts prins on your information.
08.05.2020 15:29 # 12
dinoco
[QUOTE = kankam_743] bmw ciler puts prins on your information. [/ QUOTE]
hmmmm ... good that i learned this
08.05.2020 15:29 # 13
I started to think about this LPG to 306 teams from me .. I think costly ...
08.05.2020 15:29 # 14
furkanbaki
I got my 206 xr vehicle worn out, I said I will not pay more money to the master, he said, go get paid if you are satisfied with it, come and pay it. Also, if you are not satisfied in 3 months, you will get it without question.
08.05.2020 15:29 # 15
dinoco my brother, we always peel again.
once master :))
I do not know the spray system, but I think it should be in full order. If the boy is in charge, all the brands will work after he knows how to wear it properly. get enough smooth assembly.
If you want, there is the center of the poor in the emir. I recommend a "polar lpg" interviewer. Like 1350TL, it's pretty scarce.
The machines in that carina should be similar to the engines in the corona. 2.0 16V 128bg ... they are very beautiful vehicles. convenient and comfortable to use. That knife will go away in the press ...
08.05.2020 15:29 # 16
dinoco
evt I want an lpg kit that won't upset me (TÜPPP :)))
Because I use cycles, sometimes I shouldn't be afraid that when I compress carina, I can't raise a head.
Or if everyone mixes lpg and gasoline and gives something, he says something.
The car is very clean, I'm afraid to break a car like the first day .. tskler interested .. don't be missing
compotive cant bought it today 15 inch bembeyazzzzzzz .. i dealt with them i haven't been very active today ..
I go to the body shop that has never been used in my thought, now they have done it .. Thumbs Up
Dinoco 2011-05-28 18:44:57
08.05.2020 15:29 # 17
[QUOTE = dinoco] yeah I want an lpg kit that won't upset me (TÜPPP :)))
There is no such thing as not being able to produce gas. this is either the wrong scarce choice or it is caused by improper installation or adjustment. In a few cases, there may be a regulator error.
brother, I close the dial with the waste that the millet is disliked Gülme We went to the video while we were going to the air. I hit the redline neither passes with the gas nor mixes with the gas. To try it, I gasted it at full throttle, so nothing has changed. I must be surprised by the side of the lpg, do we tickle :))
Besides, if I am not ashamed, I will buy 100 liras of gas at 10,000km. I spend so little gas ...
I'm telling you not to rub myself or my car, but to know how to do something.
some people are misinterpreting my expressions like this, so i need to explain this
Let the master be the master, know how to properly set up and adjust. Usually the scarce is not a crime. I say that errors arising from scarce are rare, but for example, I came to print. We changed the regulator incorrectly and finished ...
But this is a very variable master factor, so lpg system is good luck
08.05.2020 15:29 # 18
sedatdatse
Hi
there are 2A izmir otagaz in the karabakh
I would recommend brc region dealer
0232 253 71 85 erkan bey
08.05.2020 15:29 # 19
dinoco
Thank you very much. I thank you very well indeed, water was sprinkled inside me :)
And I say how many times I said tube, no click, you have it :)))
Dinoco 2011-05-28 22:25:12
08.05.2020 15:29 # 20
[QUOTE = dinoco] Thank you very much. I thank you very well indeed, water was sprinkled inside me :)
I am aware but you are consciously certain :))
Page : / 2
