WHICH IS THE MOST SUITABLE ENGINE OIL FOR 206
08.05.2020 18:52 # 1
scarymann
Hello friends, today I decided to change the oil of my 206 1,4 xs lpg car. I went bp. I think it would be recommended to change the oil to 100tl with the task of changing oil. But I bought 20.50 oil for castrol lpg, which is more suitable for my cousin on the phone, which is 50tl more cheaper and does not matter. But it was stuck in my mind, I put the wrong oil. Is there any harm to the vehicle? If I change the oil again after 4 months, it would be late.
Waiting for your help and suggestions to friends ....
08.05.2020 18:52 # 2
herry
The brand of oil used by services for gasoline 206 is exactly this; Total Quartz 700 10W40
08.05.2020 18:52 # 3
suppor
Mobil 1 5w30 esp formula
08.05.2020 18:52 # 4
SEZGIN72
FACTORY RECOMMENDATION:
TOTAL QUARTZ 9000 5W-40.
My Humble Suggestion and my own use: Mobil Super 3000 X 5W-40
Of course, it is okay to put it in 10W-40.
You put 20W-40. It was a little wrong choice. I recommend you to change it. 20W-40 was a bit of a minibus job.
Good luck with.
SEZGIN72 2014-11-06 11:19:20
08.05.2020 18:52 # 5
muhammed.ceyhan
my teacher is used at 20.50 tofaş. don't make a mistake like that. You need to use 10.40.
08.05.2020 18:52 # 6
Barut
It was a very wrong choice, I think, pour that oil without damaging the engine.
08.05.2020 18:52 # 7
burakbaykal2
As most friends say, 20-50 thickness oils should definitely not be used. For diesel 1.4 HDI, I have been using 10-40 for years. Even a recommendation to you is putting 50 liters of fuel at 5000km (10.8LT corresponds) and I put half a liter 10-40 into the tank. It contributes incredibly to the diesel filter, both the fuel chamber and the correct combustion situations. 10-40 no wonder you.
08.05.2020 18:52 # 8
Sercan Mungan
I would recommend Castrol edge 5w40 fully synthetic engine oil.10w40 can not be put in harm, but as a result, a semi-synthetic oil is your decision.
08.05.2020 18:52 # 9
ibanez_022
How did the officer, who put that oil in it, not allow it, change it to the car immediately, hojam ... I know 206w 10w40, but those who say 5w40
08.05.2020 18:52 # 10
samet206
(10w40 - 5w40) These are being put in for 206s. I have never heard for 20w50 206, why did you run cheaply in the oil business, how good lubrication is so good performance and engine life. Is there any harm or not? issue.
