Which is the 206 lighter fuse |
| 08.05.2020 16:19 | # 1 |
lkr_yldz |
| 08.05.2020 16:19 | # 2 |
AliOzagan |
If it does not matter in the interior due to the model difference in mine.
| 08.05.2020 16:19 | # 3 |
The locations of the fuses in the fuse panel may vary depending on the vehicle's production date. It is the best to look at your booklet, but you can check the 20-ampere F23A and F23B fuses in the fuse panel in the sofor location. |
| 08.05.2020 16:19 | # 4 |
lkr_yldz |
[QUOTE = koliva] Depending on the vehicle's production date, the locations of the fuses in the fuse panel may vary. It is the best looking at your booklet, but you can check the 20-ampere F23A and F23B fuses on the fuse panel in the sofor area. [/ QUOTE] I have an article showing the insurance information. he talks about the fuses you said, but I couldn't find them in the fuse under the steering wheel, except for f23, the f18 fuse runs the same parts but I guess the room is not under the steering wheel. |
| 08.05.2020 16:19 | # 5 |
If you can send your vehicle's production date, DAM number, I can definitely answer. DAM number: |
| 08.05.2020 16:19 | # 6 |
lkr_yldz |
Thank you very much, I can come home in the afternoon and look over the vehicle.
| 08.05.2020 16:19 | # 7 |
lkr_yldz |
1060881 dam code
| 08.05.2020 16:19 | # 8 | |||||||||||||||
[QUOTE = lkr_yldz] 1060881 drip code [/ QUOTE] You need to check the 30 Amp F22 fuse. F22 & nbsp; & nbsp; & nbsp; & Nbsp; 30 A & nbsp; & nbsp; & nbsp; & Nbsp; Front courtesy light, front map reading light, lighter.
