Which Gear Will It Burn Less?
08.05.2020 20:37 # 1
Brcbyrktr
Good luck Friends .. A topic that I couldn't learn clearly around me. Maybe it may sound funny. 206 When I go with my 1.4 hdi vehicle with 70th gear (2000 rpm) or 5th gear with 80 (2000 rpm) it consumes more fuel. In these two cases, the needle is between 2000 or maximum 2250 cycles.
08.05.2020 20:37 # 2
aykutbayram1996
Less gear for 5 gears, thanks to the gear.
08.05.2020 20:37 # 3
onlycihan
Even if it is the same, the 5th gear will burn 5 less because it will reach your destination in a shorter time.
08.05.2020 20:37 # 4
ggitaristt
Brother question is difficult .. In someone, the engine will run shorter but the wind resistance will increase, naturally it will burn a little more.
In short, it will not matter much ..
Arrangement: I realized after the diesel .. If I was, I would invest my money in the little fuel when it goes 80km / h .. Because I followed my 110hdi minimum fuel consumption at 5th gear 80km / h .. It is almost the same in 4th gear but 5 a little less ..
ggitaristt 2017-11-01 13:02:21
08.05.2020 20:37 # 5
uzunca961
I was curious about this question. What will the trip computer show, let me try it if I don't forget today
08.05.2020 20:37 # 6
Oktkor
My trip computer is the best 5 gear at 1800 rpm. :) 1.6
08.05.2020 20:37 # 7
KILIC
5, you have lower fuel consumption in gear. 70, after 5 km speed, the gear burns less than 4th gear.
08.05.2020 20:37 # 8
onlycihan
What are we calculating? What does it matter anymore? What should the vehicles do for these fuel money? The man says on Facebook that I get 20 liras of gas.
08.05.2020 20:37 # 9
ggitaristt
Yes, I also buy 100 lira once a month. It didn't matter to me either. It used to go to 100 lira 600 km now, it is going 400 km. Slowly we ride less. Big smile
08.05.2020 20:37 # 10
KILIC
[QUOTE = ggitaristt] Yes, I get 100 lira once a month .. It didn't matter to me either. It used to go to 100 lira 600km now it is going 400km. We ride less slowly. Big smile
400 km is very good for 100 lira. I hardly see 350 for 100 lira here :)
08.05.2020 20:37 # 11
tired06
I am going from 100 to 370-380 pounds
I think it burns less in 5th gear but it doesn't matter much.
08.05.2020 20:37 # 12
uzunca961
The issue of raise is a bit of a problem.
In response to your friend's question, I tried it today and let me write down the value that the trip computer gives.
4 speeds at 2000 rpm, around 75 fuel 4.9
5 speeds at 2000 rpm, speed 85 was fuel 4.7
I did not try in 6 gears there was a bit of traffic
So of course the 5th gear for both fuel and time savings
