Which engine oil to 307 lpg - 307 sounds
08.05.2020 16:17 # 1
nteker
Friends searched in the forum, I could not find the answer to this question. Which engine oil would you recommend for the 307 lpg vehicle, and should we add a boron additive? When I go with my car, I already get the road sound inside (Tires new Yokohoma C Drive 2, rot-balance okay) and also when I get on the throttle, there is a strange engine sound (when the rot-balancer vehicle drives for control, it sounds like the filter performance filter is asked me but I used a normal filter). I am waiting for your help on these issues.
08.05.2020 16:17 # 2
When the vehicle is LPG, it does not show any change. You can use the same whatever oil you are using. However, the generally used semi-synthetic is that you use 5-40 instead of 10-40, which is full synthetic ... Its brand is not very important. Total Quartz 9000 5-40, & nbsp; Mobile Super 3000 X1 5-40 etc. You can prefer all brands
& nbsp;
The tires you have as road sounds are very good quality tires, but you need to look at their history. If it is old, it may be hardened. But let's say there aren't many cars in our day that almost do not get the sound of tires.
08.05.2020 16:17 # 3
nteker
Tire dates new cecoli.
08.05.2020 16:17 # 4
metin
Do you check the door wicks, it gets old even though it gets sound inside, when it comes to the sound coming from the engine, there are felts under the windshield between the engine and the front console, they prevent them from passing sound, do you have them? is it sound
08.05.2020 16:17 # 5
nteker
There are many places such as intermittent, very old in felt. I said to the service, let's change it, they said it is difficult.
I don't know where I can change the door seals. Special services are awful in the month, and I do not see it enough in the authorized service.
