Which brands have the same rim as peugeot?
08.05.2020 17:40 # 1
For example, would the Citroen or Renault rims be on my Peugeot 206? Stud spacings. Which brands are compatible. hLL 206 2013-06-08 12:59:52
08.05.2020 17:40 # 2
allppeerr
My teacher question is, whatever rim would fit in the wrong 4 x 108 bijao intermittent fender
08.05.2020 17:40 # 3
[QUOTE = allppeerr] My question is once the wrong rim fits into the fender of 4 x 108 bijao intervals [/ QUOTE]
Okay, I meant him too.
hLL 206 2013-06-08 13:11:19
08.05.2020 17:40 # 4
Aziz
the only answer was enough. Fits 4 * 108 ones. most brands are also available. He said for the width of the sidewall and the tire width when he said it fits in the opening, so he should not wear 206 for example 225/50/17: D
08.05.2020 17:40 # 5
Alicilik
Usually 4 studs ford are sleeping. Ford pejo are like brothers: the same from the d engine to the hold stud range.
Citroen, you know, cars that come from different doors of the same factory.
08.05.2020 17:40 # 6
cerci07
fits citroen peugeot and ford lar 4 wheel bolts
08.05.2020 17:40 # 7
samet206
Ford and Citroen's 4 wheel bolts and 4x108 wheel spacing rims fit the peugeot.
08.05.2020 17:40 # 8
rolandgarros
i know that ford and citröen are sleeping but you search as 4 * 108 definitive solution
08.05.2020 17:40 # 9
Thanks. I will also search for him.
08.05.2020 17:40 # 10
rolandgarros
You can choose the bolt spacing from the owner when you choose 4 * 108 from there, you will only choose the rim size. Smile
08.05.2020 17:40 # 11
[QUOTE = rolandgarros] You can choose the wheel bolt range from the owner and when you choose 4 * 108 from there, you only have to choose the rim size. Smile [/ QUOTE]
Thank you for your interest.
08.05.2020 17:40 # 12
rolandgarros
you are welcome, if you are unstable between the models you like, share your pictures, tell our ideas Smile
08.05.2020 17:40 # 13
Aziz
[QUOTE = rolandgarros] you are welcome If you are unstable among the models you like, we share your pictures and share our ideas. Smile [/ QUOTE]
+206 Wink
