which brand should I buy
08.05.2020 18:53 # 1
mican69
I think I will buy tires for my friends vehicle (206) for the first time.
08.05.2020 18:53 # 2
fxmen
I did a lot of research while buying a tire. I recommend Kumho brand with the advice of a friend in the forum.
08.05.2020 18:53 # 3
mican69
HABAM CVP AND THANKS FOR YOUR ATTENTION. HOW TO KEEP THE FALAN FALAN WHEN YOU ARE ZAHMET WHEN YOU ARE ZAHMET?
08.05.2020 18:53 # 4
zr`lmn
I use goodyear efficientgrip performance at 307. It is about 8 thousand km and I'm very pleased. The braking dry braking distance is quite satisfactory. I did a lot of research and I'm not regret
08.05.2020 18:53 # 5
fxmen
[QUOTE = mican69] HOCAM CVP AND THANKS FOR YOUR ATTENTION. HOW TO KEEP THE FALAN FALAN WHEN YOU ARE ZAHMET WHEN YOU ARE NOT USING [/ QUOTE]
I like to drive hard in April.
08.05.2020 18:53 # 6
ibanez_022
do you think of a suitable brand? soft or hard? for example they say good continantel in terms of performance braking distance etc .. michelinn for comfort varies accordingly .. i put on affordable tracmax .. soft pulp tire .. very satisfied
08.05.2020 18:53 # 7
Sercan Mungan
If it is going to be a snow tire, I would recommend the nokian brand and besides all, here is the campaign.
08.05.2020 18:53 # 8
GokhaN
I recommend goodyear and michelin are good.
08.05.2020 18:53 # 9
pt206
For 206, I bought Pirelli P1 Cinturato, which I never thought when I said Continental, continental 1 month ago and I am really pleased. I have researched it after receiving it and the most important feature is megerse :).
08.05.2020 18:53 # 10
mehmethannn
I have been using petlas for years and I am very satisfied,
Both Turkish brand and price are suitable.
I use the vehicle normally and calmly.
08.05.2020 18:53 # 11
pusutr
I will recommend lassa. because I have a valid reason.
When changing the front row last year, a piece of L iron (holding the hoses-wires) was screwed on the inside of the left front wheel with the L side out. And every time he turned, he ate the tire from the inside. The tire is full of scratches from the inside. And especially a scratch was so deep that there was 1mm to the tire shatter or not.
Of course, I could not see so well then. because I was not at the beginning of the vehicle while the front layout was being changed. the mechanic had said that you should just replace it.
And in January of this year I bought 4 wheel lassa. And I had the chance to see the wheel clearly. Imagine that I have traveled 100 km / h with that wheel many times. with my family. with my relatives.
Unfortunately, if the quality of Lassan was not available ......
For this reason, I guess I can never give up lassa after that ..
I think you should not shorten the money to be given to the wheel. Because good wheel, its place comes, it saves your life.
pusut is 2014-11-21 11:03:00
08.05.2020 18:53 # 12
denizci33
i agree about lassa; I also have lassa; people say harsh but forget the ways of my country. Yes, the tire is hard, but as safety, it is great as a grip and I have entered such strange roads; neither the balloon nor the knowing nor the swelling .. solid as a stone.
