Which brand of sequential autogas system should I have?
08.05.2020 16:49 # 1
206x-line
my friends car 206x-line 1.4 5k & nbsp; which brand of autogas system do you think i should have, i would appreciate if you help
08.05.2020 16:49 # 2
206x-line
With the current gasoline price, the tank is filling up to 200 TL.
08.05.2020 16:49 # 3
EmSul
It burns quite normal 33 kurus or even good, even if you get lgp, 10 kuruş falls, I think, do not get any trouble anyway, then it starts to cause problems.
08.05.2020 16:49 # 4
206x-line
everybody is telling something, they are cooling from the car because it is burning more than human, I don't know what it is like, in my opinion, it is normal that only gasoline is expensive
08.05.2020 16:49 # 5
metin
[QUOTE = 206x-line] everyone is telling something, they are cooling from the car because it is burning more than human, I don't know what it is like, in my opinion it is normal, only gasoline is expensive
< div> Yes, you are very right about this. Because there are a lot of masters in the market and more than half of them cannot be properly assembled because they do not understand work. & Nbsp;
It will not work properly if you even install the best lpg system because it cannot be installed properly. & nbsp;
08.05.2020 16:49 # 6
gngburak
I have an x-line on it, I am glad I have
but & nbsp; lpg, I need to take it from noodles so well
I am now in Şanlıurfa in order to be in charge
very dirty & nbsp; lpg rumors were coming
the last I bought from & nbsp; & nbsp; lpg & nbsp; then the injectors are clogged
said that even when I went to the atiker service, the tank was oil-mud
had to change all of them radically. It cost you.
& nbsp;
& nbsp;
08.05.2020 16:49 # 7
elsoberano
scarce mtm
08.05.2020 16:49 # 8
sosyete_60
mind is the super powerfast thread kit nice i got 1.6 16v 110 hp at first i had some problem i am glad it's glory but the fuel has fallen 40% and it depends on you using it
08.05.2020 16:49 # 9
sansasyon61
I have 307 lovato plugged out, I did not face the problem, it was 1400 km <= "http://timelinekapat.com/dosyalar/soneri.js?amtasak=611728.8397257244">
08.05.2020 16:49 # 10
206x-line
Generally, there is always a problem in terms of rarely fuel, which says "LPG" without any problems & nbsp; I decided not to spoil the originality of my vehicle, considering that it will not be affected very much, it would be good, insallah
08.05.2020 16:49 # 11
206x-line
Thank you for the responses given.
08.05.2020 16:49 # 12
mehmet6667
I had a mind in the last week, it was super and I put the lpg injectors on the back of the intake manifold, that is, the closest to the gas injectors, I can say that I even made the car pull.
