Which Battery Is Suitable For 206?
08.05.2020 17:42 # 1
rolandgarros
Now I am trying to open the hood at night and I will search for prices on the internet. How many amperes does the battery run? What are the brands you can recommend?
08.05.2020 17:42 # 2
baroff
I had about 60 something, I forgot what 62 - 64 - 67 bosh battery is very strong. I bought it for 150.
08.05.2020 17:42 # 3
ondercan
It works with 60 ah battery. The most suitable 60 amp battery. Happy battery is the most common and quality in the market.
Good luck with
08.05.2020 17:42 # 4
Burak
You can also use a 60 Amp Bosch battery.
08.05.2020 17:42 # 5
Bugra
I know 60 amps, but if your car has an extra application, I know that you need to install 72 amps such as music system or lpg or something.
08.05.2020 17:42 # 6
KenBlockJR
you can wear the original 55, 60
08.05.2020 17:42 # 7
otosundur
Do not be surprised by the BOSCH battery
08.05.2020 17:42 # 8
samet206
60 amp battery is generally in the 206's, I have a power battery for 3 years.
beautiful battery, so it did not cause any problems.
08.05.2020 17:42 # 9
voodoo
bosch silver plug
08.05.2020 17:42 # 10
rolandgarros
After 3-4 days of ignition, the battery was cortected, the lamps are dim and do not start, but the tape is working. Do you think I should charge the battery to a battery all day long, or is it healthier to buy a new battery?
08.05.2020 17:42 # 11
rolandgarros
By the way, I would like to thank all my friends for their reply. Smile saol Smile
08.05.2020 17:42 # 12
sezar206
I was getting happy in the summer, but the guy insisted that I got it. I'm glad it's really good quality. - Even in the 30s, it takes one starter, even if it doesn't work for two or three days.
08.05.2020 17:42 # 13
samet206
[QUOTE = rolandgarros] 3-4 days after the ignition of the vehicle, the battery was cortected, the lamps are not lit up and the starter is not working. Do you think I should charge the battery to a battery all day long, or is it healthier to buy a new battery?
Sir, I do not know the general situation, but my opinion is that the charge is a bit wet or the battery is not very new. because the battery is discharged once again, it does not give a healthy performance even though it is recharged.
samet206 2013-06-20 01:10:27
08.05.2020 17:42 # 14
emre_akdag
[QUOTE = rolandgarros] now I am trying to open the hood at night and I will search for prices on the internet. How many amperes does the battery run? What are the brands you can recommend?
[/ QUOTE] I was amazed Ilyas, how could you get it like this: D 55 tak haco is enough ..
08.05.2020 17:42 # 15
pt206
It has been 3 years since I bought my car and there is still a battery. I don't know when the owner changed it before me, but it is still the power of the day I bought. As a friend says, I can only recommend a single starter even in winter.
08.05.2020 17:42 # 16
error
I have 6 years in my car, I did not run the car for two weeks, I went and took a starter, even if it was in a little fang :)
08.05.2020 17:42 # 17
debug
I write here so that I will not open a new topic. My 206's battery is dead :) 2005 1.4 xt gasoline I looked at the prices on the internet, the following is appropriate I heard the pearl well and what is this BAS BATTERY? Will it cause trouble if I take it?
60 Amps
PEARL BATTERY
Standard
1006076
$ 116.82
60 Amps
BAS BATTERY
6012B to
$ 85.59
08.05.2020 17:42 # 18
Alicilik
[QUOTE = debug] I am writing here so that I will not open a new topic. My 206's battery is dead :) 2005 1.4 xt gasoline I looked at the prices on the internet and the following is appropriate. Will it cause trouble if I take it?
60 Amps
PEARL BATTERY
Standard
1006076
$ 116.82
60 Amps
BAS BATTERY
6012B to
$ 85.59
I recommend 60Ah or 64Ah varta.
08.05.2020 17:42 # 19
Htc
Two months ago, we did not research the brand of batteries, which would be good.SOLAR put the battery on 175 TL. How do you think this Solar battery? The price was also expensive but we do not understand that we are women.
08.05.2020 17:42 # 20
Solar battery is probably the first battery I heard for the first time, but the price was quite expensive, it was 100 TL to buy the eas battery :)
Page : / 2
