Which antifreeze should be used for 206? |
| 08.05.2020 19:13 | # 1 |
The last time I added antifreeze, the master put blue, but I did not ask at all, now I am going to change oil again and I am thinking about changing the antifreeze.
| 08.05.2020 19:13 | # 2 |
oguzhan29 |
I was using red. In the maintenance, the entire authorized service changed and put blue.
| 08.05.2020 19:13 | # 3 |
I recommend using Blue Castrol. It has been 2 years and many processes have been poured, and most of it has been poured, water is always added on the measurements. It still shows -20 and there is no distortion in color. You can find it in most places. The red ones are a bit stronger, but they are breaking down the cooling systems of the cars, especially the old ones. |
| 08.05.2020 19:13 | # 4 |
Use green original antifreeze is not very expensive anyway.
| 08.05.2020 19:13 | # 5 |
I put it in red, but good luck, when there is a blue, when I look at the water container from outside, I could see what this captain is, I can't see it now. I always have to open the lid to check. |
