Which amplifier can I choose?
08.05.2020 19:03 # 1
efesbright
Hello friends,
I want to get your suggestion and opinion from you on a subject. First of all, the sound system of my car 207 and above is now;
2 sets of components HERTZ ESK165
I don't know 1 kicker 30cm bass technical data, but something like 300 watts.
1 x EDISON ED-1100AB MONO BASS amplifier
1 cadence 4x100watt rms / fx 104 stereo amp.
Now I have this system, I am very satisfied in my car but
Occasionally, the sound in the left front door mid is reduced by up to 10%, and the loudness of the right front door speaker increases, making it sizzle. There is no problem in the connections at the back, this sound improves when I hit the Turkish logic amphitheater. but when the vehicle moves, it starts to sizzle again when it shakes and the trouble continues and the sound becomes unbearable in the vehicle. When I turn off the sound, the sizzle continues in the right front mid team.
so I want to change the amp, I think it failed. Which amp would you recommend to feed the 2 sets hertz old 165 series mid set? or is the solution to the above fault simple?
08.05.2020 19:03 # 2
Alicilik
I use xetec. Let the amp value always be higher than the value of the track used. You will not get tired of the amp and use it more comfortably.
In my 4ohm, it gives 4 channels 90w rms single channel 300w rms. I bought 5 channels so that he did not have two amps, I regret it. Over time, his amp was insufficient when he strengthened his ten mid team and bass.
Roadstar jameson edison can also be used so that the amps of the Xetec alpine hertz fit the buffet.
08.05.2020 19:03 # 3
pejo34
First, there may be a breakage in the amplifier cable. Check the Deck Cable. It may not be chassis. If there is no cable, you do not need to get an amplifier. If it is an amplifier, I recommend Saund Magus.
08.05.2020 19:03 # 4
serdaralisan
IF YOU WILL GET A STEREO AMP, KARDEŞİM GRÜNBERG 1800W RECOMMEND THE GERMAN, TAKE THE SINGLE PROBLEM FROM THE RIGHT OF THESE LICENSES, WITH A SOLID BIO, 1 PIECE OF THE VIDEO WITH THE JLD, 50 MITS IN THE FRONT DOORS, WITH THE VİDE OF THE MİDAR AND THE VİDE OF THE MİDİ, ONE OF THE MİDES OF THE MİDİ, WITH THE 50 LITERS OF THE JL. I HAVE A CAPACITOR IN ONE PIECE, CUTTING IN THE HIGH VOLUME, DEFECTING IN THE HIGH SOUND, I WILL REMOVE THEM, I WILL INSTALL TO SURFACE, I DO NOT HEAR THE EXHAUST SOUND WHEN I OPEN
08.05.2020 19:03 # 5
Forevery
No matter how high the quality of amp speakers, etc. are not considered in the audio systems, if the cable quality and cable connections are not paid attention, you may encounter problems such as scratches etc.
I wish we couldn't meet
08.05.2020 19:03 # 6
efesbright
Forevery brother cable connections were made beautifully, even insulated, I can say that they are wrapped well cables, but when it is made, the sound is interfering. They said from the amp. Now he is doing the same problem, but this time the sound of one speaker goes and the other one is louder and it makes sizzling and noise. It heals when the amp is hit. I looked at the cables, there is no problem. I think there's a chassis inside his amp. Is it very troublesome to have it repaired? I think it was from the amp because it recovered when it hit the amp.
08.05.2020 19:03 # 7
serkanay55
Anfin liquid may be in contact or it may be cold solder.
If you first understand from the electronics, check the other places if the solder parts in the amp are not fixed with the soldering machine.
08.05.2020 19:03 # 8
efesbright
[QUOTE = serkanay55] anfin liquid may have been in contact or it may be cold solder, that is, the solder has faded or made from condensers.
The chance of seeing fluid is very low because its amp is well protected behind the bass.
The solder may have cracked as you said most likely. I opened a very loud sound, bass was steady, and when I muted it made it clear. he was very shaken, probably because he was behind his amp. The amphitheater is a bit old, almost 10 years old. Can I take it to an electrician
