Where's the mistake ???
08.05.2020 17:04 # 1
yenice
greetings. Today, the gas light came on the road, I looked at the needle, there is no problem in the last compartment, I looked at the trip computer, it shows 90 km range in 5th gear, it is normal. Immediately 10-15km later I took the tank and took 49.5 liters. As far as I know and research, the tank takes 50 liters.
When I complete the tank after 15km after the light is on, I expect 40 liters of gasoline I expect ..
Is this a problem now? I know the tank is wrong, is it taking 55 liters? If the trip computer is getting the computer from the display, then the display may be considered wrong ..
but the pumpman was also surprised is it getting that much :)
08.05.2020 17:04 # 2
Alicilik
Don't trust the road computer too much. Because I saw 1640km from him: D
only 49.5 very well received gasoline has a problem in the pump counter I think 206's diesel gasoline all 50lt I know I bought 46lt
08.05.2020 17:04 # 3
yenice
[QUOTE = Buyer] You can't trust the road computer too much. Because I saw 1640km from him: D
after the light is on The road I traveled is at most 15km. Come on 20 or not, it was not possible, my road was 22kmy, it burned in half and just before I got home, it was 15km long before the stone cracked. It should be about 4 liters of diesel. It was supposed to take 45 liters or so, so I was busy seeing 49.7 liters in the pump :)
08.05.2020 17:04 # 4
Serkan
I bought 48 liters in his biker, the trip computer did not show the range as it fell below 50 km
08.05.2020 17:04 # 5
206206
red & nbsp; after lamp & nbsp; go & nbsp; Road & nbsp; 206 & nbsp; from & nbsp; 206 & nbsp; notices either & nbsp; as & nbsp; very sensitive & nbsp; After a setting turns red, after 10 km & nbsp; let the fuel run off completely & nbsp; Stop & nbsp; I came across 206 la.
08.05.2020 17:04 # 6
feline
friends, when i went below zero, i bought diesel from the pointer shell 53.5 liters took the setting off i said i went gone, i checked the fuel in the fuel tank 52 liters came out how i said it was already gone until i went to the 1.5 liter service man in the service there 55 takes the brother said & nbsp;
08.05.2020 17:04 # 7
Bugra
[QUOTE = feline] friends when i went below zero i bought diesel oil from the pointer shell i took 53.5 liters the setting is broken i went gone I checked the fuel in the fuel tank 52 liters output how i said i said it already went to 1.5 liters service the guy in the service got 55 said brother & nbsp; [/ QUOTE]
50lt at 206's factory catalog. How would it take 55 liters? Come on, do you get the pattern with pipes in 5 liter pipes? bidet service says this. really interesting. & nbsp;
as far as I know the red light means 3 liters of fuel is left after the light comes on. time shows wrong.
08.05.2020 17:04 # 8
35-4o km of light goes out without forcing the basin, I am going ... after that, I get gas after that. It is 50lt for fullama ....
my vehicle; peugeot 206 1.4 XR automatic transmission
08.05.2020 17:04 # 9
freeger
It happened to me at once, I was stubborn not to get fuel from the ground on the intercity road, I had to go about 90-100 km to the petrol station and when I last entered it took 49 liters of fuel. The tank capacity is 50 liters, but some of the pumps fill up to 2-3 liters from time to time.
08.05.2020 17:04 # 10
technodex
Yes, if friends are writing 50lt, it takes 55 liters to buy, even if you fill it up by making normal larynx, I had a fight with the guys for the first time, there are 3 cards here, & nbsp; but it does. :)
08.05.2020 17:04 # 11
baris5537
I don't think I can see how many liters the tank will hold when pushing the liter of gas 5: s
08.05.2020 17:04 # 12
Aziz
friends & nbsp; 2 - 3 liters & nbsp; & nbsp; I heard from sometime pump because there was spare part, but for fiat - ford brands, company vehicle albea mjet 50 lt and shell vehicle due to the obligation to recognize the vehicle, the indicator burned at fsm bridge, came to izmit halfway including highway, about 110 km, fulledim bought 51.40 lt full, I believe it made 110 km with light. I pressed the starter 3 times, it worked, I think I finished the sludge in the tank until the dirt :)
