Where's the 307 reversing sensor?
08.05.2020 16:12 # 1
I bought a parking sensor on my vehicle, but when I put it in reverse, the lamp does not light up. The bulb is solid. 2011-10-07 20:19:59
08.05.2020 16:12 # 2
does anybody know?
08.05.2020 16:12 # 3
I know "Ouch"
piece 19. On the transmission.
08.05.2020 16:12 # 4
from where I can reach, which parts are close, I guess, I guess it is necessary to remove the air filter or something complete.
08.05.2020 16:12 # 5
[QUOTE = HuseyinTurk] where can I reach the place described, I guess which parts are close, I guess it will be necessary to remove the air filter or something [/ QUOTE]
Exactly. You will see the air filter and its box inserted right on the transmission. You need a deep 22mm socket to insert.
Have you checked the fuse?
koliva 2011-10-07 20:39:02 < / edited>
08.05.2020 16:12 # 6
The distinction is that it was his insurance but I never thought it was possible because the park's insurance is right and left two only but my first job is to check those fuses, thank you for the information
08.05.2020 16:12 # 7
The distinction of [QUOTE = HuseyinTurk] is that his insurance was not possible but I did not think it was possible because the parks' insurance is just two left and right, but my first job is to check those fuses for the information [/ QUOTE]
10 amperes F1 fuse in the fuse panel. However, you can still view your owner's manual.
08.05.2020 16:12 # 8
mehhhmet80
S Peugeot 307 AUTOMATIC TRANSMISSION CAR's REVERSING could not FIND the Musuri PARKING SENSOR wear made REVERSING LAMP to INACTIVE FOR where ELECTRICITY GO LAMPS SEVİNİRİM If STRONG BUT HELP COULD
08.05.2020 16:12 # 9
mehhhmet80
08.05.2020 16:12 # 10
mesutay20
If it is not from insurance, it is the client. when you take the car to your front, it's on the right side under the glass. of course the air filter will be removed and b you better make it to a master. I made it last month. Sender: 25 TL Removal: 10 TL
08.05.2020 16:12 # 11
heffera
307 hdi 2005 the location of the reverse gear insurance and who knows which channel? There are fuses at the bottom left of the button, but if there is a very complicated there, which fuse emergency reverse light does not come on. lamps are intact ..
08.05.2020 16:12 # 12
heffera
In my sources, it is referred to as 10 amp F1 fuse in the fuse panel in the engine section. However, you can still see your user manual.) TŞK Koliva gb. When I bought 10 amps of F1 fuse did not come out, I will write for those who do not know the fuse of the 307 HDI reversing lamp.
08.05.2020 16:12 # 13
[QUOTE = heffera] In my sources, it is referred to as 10 amp F1 fuse in the fuse panel in the engine section. However, you can still see your user manual.) TŞK Koliva gb. When I bought a 10 amp F1 fuse did not come out, I said I would write for those who do not know the fuse of the 307 HDI reversing lamp. [/ QUOTE]
Thank you.
08.05.2020 16:12 # 14
ByHack
the socket can loosen the socket, take it out, do not even have a short circuit.
