where is the slave lamp and the sunshade lamp stand |
| 08.05.2020 16:29 | # 1 |
ares2626 |
| 08.05.2020 16:29 | # 2 |
I think, check all the fuses in the fuse table one by one and change the defects to the same value and overhaul them all. It would be nice if you are interested in this problem.
| 08.05.2020 16:29 | # 3 |
ares2626 |
tskkrler.usta checked the voltage of the majority, but said that the problem is not seen, if anyone has experienced this problem before, I will take that queue and install a new one.
| 08.05.2020 16:29 | # 4 |
it is not difficult to install a new one. It can even burn the car. If you didn't ask the master, why is the insurance throwing?
| 08.05.2020 16:29 | # 5 |
[QUOTE = ares2626] tskkrler.usta checked the voltage of the majority, but he said that the problem does not appear, if anyone has experienced this problem, I will take it out and install the new one. [/ QUOTE] |
| 08.05.2020 16:29 | # 6 |
ares2626 |
No, it is not always a beating, we call double dn fln, then it threw the room, I guess from it.
| 08.05.2020 16:29 | # 7 |
then a & nbsp; If it throws up again, start looking for problems. But be sure to plug in the same value.
| 08.05.2020 16:29 | # 8 |
ares2626 |
I WILL CHANGE WHICH I HAVE CHANGED HERE I WAS NOT FIND HERE :)
| 08.05.2020 16:29 | # 9 |
all at once Check them one by one, replace them with the same value as new ones. You control all of them.
| 08.05.2020 16:29 | # 10 |
Fuse 20 Amp f7 covers: On-rear ceiling lights, map reading lab, Ten 12V socket Clamshell, Glove box lamp span > Reviews |
| 08.05.2020 16:29 | # 11 |
I think everyone should have one multimeter. 7.5 lira is something but saves lives. If there is a multimeter, it is only single chassis control is made or voltage is measured, whichever is waste is understood.It is very simple operation. It works very well in all electrical and electronic. I recommend it to everyone. title = "Wink" /> |
| 08.05.2020 16:29 | # 12 |
I also have a tool that has not worked so well in the car.
| 08.05.2020 16:29 | # 13 |
ares2626 |
[QUOTE = coliva] 20 Amp fuse F7 covers: On-rear roof lamps, map reading lab, On 12V socket Cigarette lighter, < br> Torpedo lamp lamp [/ QUOTE] God bless tomorrow, I will change the first heat, thank you. |
| 08.05.2020 16:29 | # 14 |
ares2626 |
Good day, man, if this f7 fuse is not in the hood, is the fuse of the seat in the seat?
| 08.05.2020 16:29 | # 15 |
It should be inside. |
| 08.05.2020 16:29 | # 16 |
As stated by Yavuz, in the insurance section of the seat of the Sofor. & Nbsp;
