Where is the parking sensor buzze
08.05.2020 19:06 # 1
kergom
Hi friends, I solved the malfunction that I had experienced for about 1 month yesterday.When the rev counter, the temperature indicator turned off and back on while in motion, the abs and other lights were flashing, and when the reverse gear was put in, the parking sensor was not activated sometimes, the lights on the indicator were on even though the ignition key was not attached. engine guru to, cerebellum to, locksmith (contact termiği I sent friend cerebellum for kolturol) I returned to edemedik.ev results, despite the binding went to the computer and forums Peugeot luggage to find parking sensor brain starting from here in Turkey, I researched spare wheel holder when I remove the brain that result when water filled his I saw that the water was filled in it. When I disconnected the sockets of the brain, the car returned to normal, I cleaned the brain beautifully, I installed it again, the car was not affected. I wanted to check, but I have no idea about the place where she never ever sound comes from our friend who knows Is there condensation on I wonder URKEY PEUGEOT TURKEY FORUM in the FORUM
08.05.2020 19:06 # 2
Alicilik
The original hardware buzzer? As far as I know, I'm not sure the sound was being given through the speakers. I guess there wasn't an buzzer.
08.05.2020 19:06 # 3
kergom
When I leave the key on the door and open the door, a different tone sounds, making a half contact and long pressing the button on the end of the signal lever activates and disconnects the headlight sensor.
08.05.2020 19:06 # 4
Alicilik
I don't know the parking sensor when the sound from the contact comes from that area. Let me see if there is a voice number. It is not the original sensor, it is not followed later.
08.05.2020 19:06 # 5
seydisehirli
Is the parking sensor brain inside the bumper? where exactly is the place Seydisehir 2015-02-18 08:22:54
08.05.2020 19:06 # 6
Buzzer is at the top between the steering wheel you call and the display. The ticking sound that comes out when you give a signal comes from the same buzzer.
08.05.2020 19:06 # 7
Emask
Remove the gear gaiter for the buzzer on the left side of the gear console will be in an old post on the forrm
08.05.2020 19:06 # 8
kergom
How to open is the same place in automatic gear.
08.05.2020 19:06 # 9
kergom
I saw some where the Emask friend described, looking at the cable colors, when I put a 9 volt battery from the brain socket in the trunk, I heard a voice.
08.05.2020 19:06 # 10
Emask
In my opinion, the parking sensor brain malfunctioned due to the same event. Unfortunately, I couldn't get it repaired. In the new weather, if you can get 500 odd TL.
08.05.2020 19:06 # 11
kergom
http://s1377.photobucket.com/user/kergom/media/ımg_20150217_204640_zpsa3ad9fdb.jpg.html " http://i1377.photobucket.com/albums/ah59/kergom/ımg_20150217_204640_zpsa3ad9fdb.jpg http://s1377.photobucket.co I /user/kergom/media/IMG_20150217_204702_zpsa4b13327.jpg.html " http://i1377.photobucket.com/albums/ah59/kergom/IMG_20150217_204702_zpsa4b13327.jpg " http: //s1377.photography_camps .jpg.html " http://i1377.photobucket.com/albums/ah59/kergom/IMG_20150218_163719_zpscecc5661.jpg " http://s1377.photobucket.com/user/kergom/media/IMG_20150218_163725_zps5459 : http:/ /i1377.photobucket.com/albums/ah59/kergom/ımg_20150218_163725_zps5459172a.jpg " http://s1377.photobucket.com/user/kergom/media/ımg_20150218_163736_zps69c8e11b.jpg.html " http://i1377.photobucket.com/albums /ah59/kergom/IMG_20150218_163736_zps69c8e11b.jpg "I just added the pictures, friends, our electronics worker called our brother and he would be at risk. i said i will not buy anything if i get it i said i try your luck if i asked for a price for two days i gave confirmation i made a price like 60tl. As the brain says, I will either find a new place for assembly, as our Emask friend said, or I will isolate the box in the same way (normally there are no water outlets entering the sockets mounted above) with silicone or something else. But as soon as possible, we need to remove the bumper and find a solution to the air vents, so as not to live again. Many thanks for your help, friends. I Kergou 2015-02-18 19:15:44
