Where is the map sensor socket problem :(
08.05.2020 19:34 # 1
Tunayuysal
Hello friends, I just joined the forum and introduced it to myself .. There is a problem that cannot be found in my car .. The car is feeding or gas exploding with the plug of the map sensor, but the map sensor has been tried, ignition and spark plug have been tried, the map sensor socket has been tried, even the brain has been tried but it has not been corrected. 108 608 and 114 I think I can't remember the codes. There is a fixed end fault. The error in the tested brain has been erased and again gave the same errors. But the socket of the map sensor is inserted, life is returning to normal. Even after inserting the socket, the fault light does not come on. is becoming .. Where do you think the problem is?
08.05.2020 19:34 # 2
Gokcesel
@Alicilik invites my teacher and I believe he has an idea :)
08.05.2020 19:34 # 3
Tunayuysal
Well, I would be very happy .. Atasanayide ayhan auto there is new, I liked the new person, good man made the maintenance there but his staff said the brain, he did not feel comfortable, uncle peugeot also tried a lot of things including the brain. the socket ends did not happen .. Is five volts coming or minus coming? If the pressure in the middle probe decreases as the air pressure changes, nobody was looking at it.
08.05.2020 19:34 # 4
koray.turan
The same problem is present in me. Where is this map sensor?
08.05.2020 19:34 # 5
Tunayuysal
I load the photo tomorrow, but when the hood is opened, there is a sensor with a green label on the left of the center nearest the glass. If you write Google 206 map sensor, take a photo
08.05.2020 19:34 # 6
koray.turan
When I take this out, do I misfire?
08.05.2020 19:34 # 7
koray.turan
I wonder if there is a harm
08.05.2020 19:34 # 8
Tunayuysal
There is no harm.
08.05.2020 19:34 # 9
koray.turan
Ok i'm fine my printer is here soon
08.05.2020 19:34 # 10
Tunayuysal
Friends, is there anyone to help?
08.05.2020 19:34 # 11
Tunayuysal
Friends normally disconnected the socket, there was no problem using it .. when I started it in the morning today the role was fluctuating and stopping the engine. I put the socket in order to see if there is a change .. the car that bursts, which does not eat gas, is fixed in a place over 4000 cycles when the socket is plugged in and it does not supply any gas.
08.05.2020 19:34 # 12
Now, teacher, do you have LPG in the vehicle?
08.05.2020 19:34 # 13
Tunayuysal
Yes, I have a teacher, but he is doing the problem in both gasoline and LPG, the problem of bringing the speed to 4 thousand passed by himself, but the map sensor's socket is disassembled. please someone help ..
08.05.2020 19:34 # 14
ssakyel
Sir, if the Map sensor is defective now, only the lpg should have a problem. Have you checked the idle sensor?
08.05.2020 19:34 # 15
Tunayuysal
map sensor, sensor socket, tried by changing the brain but each one has the same map sensor + tip open circuit error,
08.05.2020 19:34 # 16
ssakyel
I wonder if it is related to the connection cables.
08.05.2020 19:34 # 17
Efe-Pojo
[QUOTE = ssakyel] Sir, if the Map sensor is defective now, only the lpg should have a problem. Have you checked the idle sensor?
there is no such thing, if a sensor in the original map sensor is broken, it will also cause problems in gasoline.
08.05.2020 19:34 # 18
ssakyel
Exactly, my teacher, I am sorry if I misled it. Wacko
