WHERE IS THE GASOLINE PUMP RELAY
08.05.2020 20:29 # 1
barisnikof
Hello friends
My vehicle has not been running on gas since last night.
I run it directly by pressing the lpg button.
I have researched a little from the net that it is said to be from the gas pump relay.
1. What is your suggestion.
2. where is this relay
08.05.2020 20:29 # 2
ardacaneer
hello teacher
I had the same problem. the gas pump is located under the rear seats. We do not buy gasoline due to the use of LPG to the car, which caused the fuel pump to burn. I bought a clean-out gasoline pump and fixed it for 150 liras including labor. I recommend you have him look. Get well soon
08.05.2020 20:29 # 3
You burned the gas pump. probably. I have to have the manifold in the relay engine section. brown square will be something.
08.05.2020 20:29 # 4
boruc
He finds it under the ECU in 206. Gasoline role.
I just had a new problem
But your problem is like the pump
08.05.2020 20:29 # 5
barisnikof
Hello
yesterday morning I left the car to the master at noon.
problem: it was a gas pump
solution: 150 tl :)
thanks
08.05.2020 20:29 # 6
mustafa46
I had the same problem with me, I bought a 90 tly pump, I worked on 40 tl, I solved the problem.
08.05.2020 20:29 # 7
fatihsultan
I also changed the gas pump, it was not working in the cold, it was working in the hot kicking in the heat, they said it could be from the role, does it cause such a thing to the role?
08.05.2020 20:29 # 8
boruc
[QUOTE = fatihsultan] I changed the gas pump, it was not working in the cold, it was working kicking a little in the heat, they said it might be from the role, does it cause something like this to the role? [/ QUOTE]
I did not know if it would cause the problem you said, but it is useful to try it as it is a cheap piece.
I bought 50 tlies.
You can even try and remove it from another 206.
08.05.2020 20:29 # 9
onlycihan
Sometimes very small details can be hidden under big problems. In order for the pump to perform its duty properly, you should make sure that the relay and electrical connections are healthy.
08.05.2020 20:29 # 10
fatihsultan
Well, we'll start from the warehouse.
08.05.2020 20:29 # 11
umut1001
Friends, when I turn on the ignition of the vehicle, there is no sound from the pump, but now it does not come and the starter does not start even though it starts. Most likely it is from the gas pump relay because the car is running and sometimes this problem does not work.
Where could I not find this gas pump relay.
08.05.2020 20:29 # 12
umut1001
https://imgyukle.com/i/v24mqp
08.05.2020 20:29 # 13
omerb
Hello there,
There is a picture in the attached link. I think it is black plastic mounted in front of the medicine. I guess the attached valeo script is there
08.05.2020 20:29 # 14
umut1001
Slm.O Ecuya to attach the cables. If you are talking about the thing in front.
22.09.2021 10:16 # 15
Serbay17
hello sir, i have this problem too, did you solve it?
